02-12-2020 12:11 AM
Hello Community,
we are trying to use the vmps feature (used on Cisco 2960X before) for dynamic vlan setting. It seems that the command has been replaced by another one. Can you let me know the correct command?
IOS: Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.9.3, RELEASE SOFTWARE (fc2)
Thanks upfront
Solved! Go to Solution.
02-12-2020 12:30 AM
Its been Long I have used VMPS, as per my knowledge, Cat 9K does not support VMPS.
If your environment have ISE, i believe MAB is an alternative option ( as per my understanding).
=====️ Preenayamo Vasudevam ️=====
02-12-2020 12:30 AM
