Connect Switch Nexus 2348upq to Switch Nexus 5548 via CVR-QSFP-SFP10G
Hi all!
I'm had 02 switch nexus 5548, and now i want connect 02 Switch Nexus 2348upq to them (after that i will config eVPC on switch nexus 5k).
I see in the datasheet Switch Nexus 2348upq, if I want connect to switch nexus 5k I must use CVR-QSFP-SFP10G (transceiver).
I had buy them But when i install CVR-QSFP-SFP10G on my 02 Switch Nexus 2348upq and i check on my switch 5548, i can't see the transceiver and the port connect to switch 2k had notice " fabric down, link not connected"
What should i do now?
marce1000
- Could you post the output of show interface brief x/y/(z) of the involved interfaces on the nexus2348upq and the 5548 ?
 M.
when i "show ip int brief" my port show (Mode: fabric, Status: down, Reason: Link not connected)
 - Please post output as seen and or with cut and paste or screenshot.
    M.
