Cisco 9300 Configuration
rrocha9584
where/how can i find a cisco programmer for four (4) 9300 switches in/near tampa, florida?
independent contractor or small company.   2-3 day job maximum.  very simple network.
the support page gives me companies no closer than Houston.
Reza Sharifi
You may want to call this company.  They have 4 locations in Florida including one in Tampa.
https://www.progent.com/Progent-Locations-Local.htm
balaji.bandi
Are you Looking for an Engineer who can install you these switches near your area,? maybe check IT, network consultant - using Google or contractor can help you.
BB
rrocha9584
No these are fully installed in a rack.  there are four of them and fiber goes out around a plant and back.   we need basic configuration for the fiber to create a redundant ring.
if you have a basic idea about the switch, you can configure it yourself,  below link help you
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
this is more of a community to help any technical question help to build the config, if you do not have any hands-on experience and you looking only consultant - look as suggest local network engineer who can help(consulting company)
BB
Reza Sharifi
