Cisco 9300 switch doesn't connect via SSH
Rick001
I have a couple of switches that are trunked via a LAN cable from another switch. I noticed that these switches sometimes have a hard time to SSH into. I get the error: "Connection timed out". After a while and a few tries I can connect just fine. I checked the logs (sh log) and don't really see anything helpful.
I have the following set an all the switches:
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
line vty 0 4
access-class VTY-ACL in vrf-also
exec-timeout 9 59
logging synchronous
transport input ssh
transport output ssh
line vty 5 15
exec-timeout 9 59
logging synchronous
no exec
transport input none
transport output none
line vty 16 31
exec-timeout 9 59
no exec
The switches are up with no interruption. I can console in fine.
27 Replies 27
So there is tcp i.e. there is connection
You mention that you try connect from SW and it work
Can you check
Show tcp breif
In both case check the IP and port
MHM
Could you post the output of the command show arp on the switch?
Rick
So I have 4 switches with this issue. The "sh arp" command is showing all these switches' IPs and MAC (I believe cause I ping the other problem switches from it) with it's own IP Age being "-". The other device I see in the list is the Core Switch.
I've noticed that if from another switch I ping the IP of the switch I'm trying to SSH into
in this case you not able to SSH from device, but another device you able to SSH in that means SSH working.
when the device not able to SSH - at the time are you able to ping ?
I've also noticed that it happens to switches which are trunked to other 9300 switches via CAT 6 cabling
can you explain more - how is your network connected, when you failing to connect to other switch daisy chained and you still able to connect to main switch right ?
what IP address VLAN these switches you were able to connect ? what is the device IP from you not able to connect ?
when you remove ACL are you able to connect all the time ?
your ACL seem to be odd some  of the mask you used . can you post the switch interface config and routing table from the switch you having issue  and STP information.
BB
It is very inconsistent. Most of the times I can't SSH directly to the switch. I noticed that if I ping the switch from any other switch in the network, I can immediately access it. I can SSH into the switches without problems within any other switch.
Th problem switches just so happen to be daisy chained.
Its a bit hard to reproduce, cause once I get in, I can exit and reenter fine. I have to wait a few hours until I can't SSH again to test again.
When the problem is happening and you are not able to SSH, are you able to ping the switch? Can we eliminate IP connectivity issues?
Rick
That's the strange thing. If I want to connect, I just try to ping from another switch and it then connects.
when you have issue of the switch, are you able to SSH to parent switch or even parent switch not able to SSH ?
what VAN you use for Management ?
how does your STP configured ? who is root in the Daisy chain ?
BB
Only having issues with the child switches.
I have the Management VLAN 99 on all of the switches.
BB
I don't have any issues with the parent switches, only the child.
I only see the trunk interfaces as root.
robertpatrick
Did this ever get resolved?
The symptom - intermittent access, pinging from another switch enables access, but it breaks again hours later - sounds like an odd issue related to ARP and/or a duplicate address on the same network segment.
Depending on where you're attempting to source access, you may want to temporarily drop the ACL or add a log statement to the deny in the ACL to confirm there's no block. Also, consider cloning the VTY config lines from line vty 0 4 through 5 31, ensuring all input lines are enabled with a consistent configuration allowing login via SSH.
vishalbhandari
@Rick001 It seems the issue might be related to SSH session limits or network conditions. Here are some steps to check:
  1. VTY Lines Usage: Ensure the VTY lines (0-4) are not fully occupied when you're trying to connect. You can check active sessions with show users.
  2. Access-List or VRF: Verify that the VTY-ACL and the specified VRF are correctly configured and not blocking or misrouting your SSH traffic intermittently.
  3. CPU Utilization: High CPU usage can delay SSH responses. Check with show processes cpu.
  4. STP or Trunk Issues: Since these switches are trunked, verify if there are spanning-tree reconvergence events or interface errors on the trunk ports (show spanning-tree and show interfaces).
  5. Logs on Trunk Switch: Check the logs on the switch connecting these devices. It might reveal any upstream connectivity issues.
Testing with debug ip ssh (if safe to do so in your environment) during connection attempts might also help identify the root cause.
