Cisco 9500-16X-E not completing booting to enable mode
pappyjjboi1
My brand new out of the box Cisco 9500-16X-E does not boot past "system configuration dialogue stage" as shown in the attached image, when it reach this stage, the booting would just hang  and pressing enter or any key does not work. I can neither press "yes" nor "no" at the CLI as it just hang there. I've rebooted it severally, same issue.
Kindly assist me please.
8 Replies 8
pappyjjboi1
The console settings is incorrect.
Thanks for your response. Please, which console settings are you referring to? is it on the putty app or where?
which of the console ports are you using, the USB mini-Type B console connection, or the RJ-45 console port ? Either way, try both.
- Check console cable (on connectors) - make sure both ends have a solid  connection. Also use other console infrastructure as a sanity test.
 M.
balaji.bandi
try below :
BB
Hello
maybe just click inside the console window with your mouse then try and type:
Kind Regards
Paul
pappyjjboi1
I will try all the recommended solution tomorrow when i get to the client site as we don't work today being Sunday here. I will give update tomorrow.
I thank everyone for various swift responses.
