CISCO ACE Server Load Balance Issue
I am facing issue in my Cisco ACE L7 server load balance policy . there are two policy for total 4 server (2 for each) one load balance policy is working and second is showing down state . i have checked all the configuration and it is similar to first policy.
kindly check my below logs and attached configuration file and help me out this situation.
Policy-map : L4_LB_VIP_POLICY2
Status : ACTIVE
Description: -----------------------------------------
Interface: vlan 40 41
service-policy: L4_LB_VIP_POLICY2
class: L4_VIP_ADDRESS_CLASS2
nat:
nat dynamic 1 vlan 40
curr conns : 0 , hit count : 0
dropped conns : 0
client pkt count : 0 , client byte count: 0
server pkt count : 0 , server byte count: 0
conn-rate-limit : 0 , drop-count : 0
bandwidth-rate-limit : 0 , drop-count : 0
VIP Address: Protocol: Port:
172.17.36.98 any
loadbalance:
L7 loadbalance policy: L7_VIP_LB_ORDER_POLICY2
Regex dnld status : SUCCESSFUL
Rgx comp success cnt : 2
Last Regex comp success : Sun May 12 05:43:50 2019
Rgx comp timeout cnt : 0
Rgx comp failed cnt : 0
VIP Route Metric : 77
VIP Route Advertise : ENABLED-WHEN-ACTIVE
VIP ICMP Reply : ENABLED-WHEN-ACTIVE
VIP state: OUTOFSERVICE
VIP DWS state: DWS_DISABLED
Persistence Rebalance: ENABLED
dropped conns : 0
conns per second : 0
L7 Loadbalance policy : L7_VIP_LB_ORDER_POLICY2
class/match : class-default
LB action: :
sticky group: cookie-insert
primary serverfarm: SFARM2
state:DOWN
backup serverfarm : -
hit count : 0
dropped conns : 0
compression : off
compression:
bytes_in : 0 bytes_out : 0
Compression ratio : 0.00%
Gzip: 0 Deflate: 0
compression errors:
User-Agent : 0 Accept-Encoding : 0
Content size: 0 Content type : 0
Not HTTP 1.1: 0 HTTP response error: 0
Others : 0
0 Replies 0
