Configure proxy authentication on Cisco CAT9K Switches
Lee Win Neng
Hi, may I request for some assistance on the configuration guide on the proxy authentication for Cisco CAT9K switches which require to register smart licensing to Cisco portal. The switches was able to ping to the internet or Cisco services portal unfortunately there was proxy authentication in the customer environment when using port 80 or port 443.
Kindly need some assistance and advice on the configuration guide for Cisco CAT9K switches with proxy authentication on the second method as shown in the picture below.
Thank you for kind help and advice.
 - Check the callhome configuration cli command : you may need :
                   transport http proxy server  ?
  I mean look at the command options when the ? is inputted , you may find all options for completing the configuration of the http proxy (including a username)
 M.
Mark Elsen
 - You haven't included the picture.
    M.
As attached
 M.
