Cisco ASA 2110 - Change of FXOS Management Interface not working
amoth00011
Hi All,
I am currently trying to change the fxos management interface IP address on a cisco 2110.
I have followed a document from Cisco and followed the commands from page 16 on wards. https://www.cisco.com/c/en/us/td/docs/security/asa/quick_start/fp2100/asa-2100-gsg.pdf
Each time I set the out-of-band ip address using teh following command:
firepower-2110 /fabric-interconnect # set out-of-band ip ....  netmask ..... gw
It errors on set. I have done this command before and it worked without any issue, i also searched options to see if there was something missing but it all looks fine.
Any help is much appreciated. TIA
Douglas Holmes
Thread is pretty old.  Replying to assist someone else.
First thing is to put in a rule to allow connections to your new IP Address.  Example:
scope system
scope services
enter ip-block 172.16.200.0 24 https
enter ip-block 172.16.200.0 24 ssh
exit
commit-buffer
Now you can change the IP.  Note that it will disconnect any Web sessions you have going on the old IP.
scope fabric-interconnect a
set out-of-band static ip 172.16.200.249 netmask 255.255.255.0 gw 172.16.200.1
commit-buffer
exit
I know this is an old thread but I stumbled upon the same issue, but was able to find a solution.
So, to recap - the issue:
firepower-2110 /fabric-interconnect # set out-of-band static ip .... netmask ..... gw
The solution:
When in "ASA" mode, run the command to connect to FXOS - HOWEVER, you need to connect in "admin" mode:
cisco# connect fxos ?
admin Admin mode
<cr>
cisco# connect fxos admin
Once I did that, I was able to run the failed commands above.
