Cisco ASA 5525X and 4948E switches - Dot1Q trunking and multiple default routes
Nicholas Beard
I have the following setup -
2 x Cisco ASA 5525X Series Firewalls
2 x Cisco 4948E Switches
The switch configuration is as follows -
I have approximately 30 customers configured with internal and external VLANs -
Vlan 100
name Customer A In
Int vlan 100
IP Address 10.1.1.251 255.255.255.0
Vlan 101
name Customer B In
Int vlan 101
ip address 10.1.2.251 255.255.255.0
Vlan 200
name Customer A Out
int vlan 200
ip address 30.x.x.x. 255.255.255.248
vlan 201
name Customer B Out
int vlan 201
ip address 30.x.x.x 255.255.255.248
Each switch SVI interface has HSRP configured for HA between switches.  The default gateway for each customer is the virtual HSRP ip address which is 10.1.x.250 255.255.255.0 (where x is the customer subnet).
I then have the Cisco ASA firewalls connected to the switches via trunks as follows (there are obviously more interfaces than the two shown below, but just for simplicity) -
int gi1
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 100,101 etc
description Cisco ASA inside
int gi2
switchport trunk allowed vlan 200,201 etc
description Cisco ASA outside
The Cisco ASA devices are setup in active/passive failover HA pair and are configured as follows -
int gi1
no nameif
int gi1.100
vlan 100
ip address 10.1.1.254 255.255.255.0
nameif Customer A Inside
int gi1.101
vlan 101
ip address 10.1.2.254 255.255.255.0
nameif Customer B Inside
int gi2
no nameif
int gi2.200
vlan 200
nameif Customer A Outside
int gi2.201
vlan 201
nameif Customer B Outside
The default gateway for each customer is the virtual HSRP ip address  which is 10.1.x.250 255.255.255.0 (where x is the customer subnet).  Policy based routing is then used to route up to the Cisco ASA Dot1q 'inside' interface for the customer from the switches.  The Cisco ASA will then perform NAT before (this is where the problem comes in) routing back down to the 'external' HSRP ip address of the VLAN on the 4948E switches.  The switches will then route out to the internet.
Now, I am aware that Cisco ASA devices do not support multiple deault routes or PBR.  So I am struggling to understand how I can create a seperate route for each customer to route back down to their specific gateway (external VLAN) on the 4948E switches.  Can anybody shed any light on this, or am I overthinking this?
Nick
49xxs with IP BASE license offer the VRF-lite toolset but you can't do NAT on those boxes, so
you'd still be stuck on ASA multiple contexts... i'm sorry '-)
7 Replies 7
Hi Nick
have you considered creating multiple contexts on the ASAs?
This would allow to virtualise fw's routing tables and nat statements, you could
create for instance a context for every group of customers and some contexts
for your uplinks.
That's an example:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml#asdf
And keep in mind current limitations about vpns and dynamic routing protocols:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/mode_contexts.html#wp1188973
Hi Francesco, thanks for the response.
Yes i had previously considered using Multiple Contexts but was hoping to avoid the additonal cost that comes with the extra licences, as by default you only have 2 with the 5525.  I believe there is also a limit of 20 maximum contexts on the 5525 which is another possible problem.  We are also looking to utilise secure site to site VPN and I am aware you lose that functionality with contexts.
In short, I was hoping to utilise DOT1Q and VLANs to perform this as it is by far the most cost effective and functional (possible) solution.  At this point however, I do not know if there is any method I can utilise to route back down to the 'outside' SVI once the NAT has taken place. I think we may be stuck and therefore have to succumb to the requirement for the security contexts.
Nick
If you go with a 5540, the number of context goes up to 50, if this number is good enough for you.
The price difference should not be much.
table-1 in this link:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/data_sheet_c78-701808.html
Reza,  Thanks for the response unfortunately we have already purchased the Cisco 5525X Series.
I was doing some further thinking on this and believe if I remove the external VLANs from the 4948E switches and terminate the ISP connection into the Cisco ASA instead, all networks then become directly connected to the Cisco ASA.
I can then route traffic up to the ASA from the internal subnets (10.1.1.x, 10.1.2.x etc) and perform NAT on each internal subnet to their specific public subnet on (30.x.x.x/29).  If i then have a public ISP facing interface (60.x.x.x) on the Cisco ASA and perform a default route as follows -
Interface ISP - 0.0.0.0 0.0.0.0 60.x.x.x
This should work because the ASA will receive the internal LAN traffic, NAT the trafffic to the /29 subnet and forward it because this is directly connected route to the next hop upstream (ISP Router).
Can anybody think of a reason this would not work?
Nick
if you don't have multiple uplinks, didn't
you overthink the whole issue?
you re just NATting internal subnets (on the
asa) that arent directly connected... am i making
it simpler than it really is? at first you mentioned
PBR but if you have single upstream this is not
what you need. that should work as you have
deescribed in your last post...
Nick,
You can create multiple default routes ... up to 3.  It does not show up well under testing however ...
Nick
