Cisco ASR 1002 - OID for CbQos
Frederic RIBES
Hi all,
I would like to get CbQos on a Cisco ASR 1002S (IOS-XE Software (PPC_LINUX_IOSD-IPBASEK9-M), Version 15.1(1)S1).
With the standard OIDs (cbQosIfIndex - 1.3.6.1.4.1.9.9.166.1.1.1.1.4), I can't...
So, is it possible ? If it is, which OID ?
Thanks in advance.
Regards.
ameya_oke
HI,
PLease use below commands in ASR.
RTR(config)#configure terminal
RTR(config)#snmp-server ifindex persist
RTR(config)#snmp mib persist cbqos
Below is link for all the OID with CBQos.
http://www.oidview.com/mibs/9/CISCO-CLASS-BASED-QOS-MIB.html
Hope it helps.
Warm Regards
Ameya Oke
Thanks for your help Ameya,
Unfortunately for ASR router, the OIDs provided in your link are those I am currently using but the result is :
snmpwalk -v 2c -c SNMP_community IP_adress 1.3.6.1.4.1.9.9.166
SNMPv2-SMI::enterprises.9.9.166 = No more variables left in this MIB View (It is past the end of the MIB tree)
IOS is : IOS-XE Software (PPC_LINUX_IOSD-IPBASEK9-M), Version 15.1(1)S1.
So, is it particular for this kind of IOS to see COS by SNMP on ASR routers ? Is there another diffrent OID with CBQos for this IOS ?
Another idea ?
Thanks in advance.
Best regards.
UP
Any idea ?
Thanks.
Same here.
Did you found how to do?
