Current ios: asr1000rp2-advipservicesk9.03.05.00.S.152-1.S.bin
From logg:
14E cpp_common_os:7F6282A85000+1902E cpp_sbs:7F6289A1A000+B0D7 cpp_sbs:7F6289A1A000+85C6 cpp_sbs:7F6289A1A000+8494 cpp_ipfrag_svr:7F628A6A3000+D45F cpp_ipfrag_svr:7F628A6A3000+7FA0 cpp_common_os:7F6282A85000+116AE cpp_common_os:7F6282A85000+110EA cpp_common_os:7F6282A85000+10F2B evlib:7F628
Nov 27 02:25:44.566: BGP_Router: unhandled major event code 128, minor 0
Nov 27 02:25:44.573: %CPPDRV-3-LOCKDOWN: F1: fman_fp_image: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Nov 27 02:25:44.767: BGP_Router: unhandled major event code 128, minor 0
Nov 27 02:25:45.257: BGP_Router: unhandled major event code 128, minor 0
Nov 27 02:25:45.357: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0 desc:INFP_INF_SWASSIST_LEAF_INT_INT_EVENT0 det:DRVR(interrupt) class:OTHER sev:FATAL id:2121 cppstate:RUNNING res:UNKNOWN flags:0x7 cdmflags:0x8
Nov 27 02:25:45.357: %CPPHA-3-FAULTCRASH: F0: cpp_ha: CPP 0 unresolved fault detected, initiating crash dump.
Nov 27 02:25:45.358: %CPPDRV-6-INTR: F0: /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/cpp_driver[6277]: CPP10(0) Interrupt : 15-Nov-27 11:25:45.351361 UTC+0900:INFP_INF_SWASSIST_LEAF_INT_INT_EVENT0
Nov 27 02:25:46.991: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
Nov 27 02:25:46.992: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F1
Nov 27 02:25:50.136: BGP: topo global:IPv4 Unicast:base Scanning routing tables
Nov 27 02:25:50.136: BGP: topo global:VPNv4 Unicast:base Scanning routing tables
Nov 27 02:25:50.136: BGP: topo CLI:VPNv4 Unicast:base Scanning routing tables
Nov 27 02:25:50.136: BGP: topo EXT:VPNv4 Unicast:base Scanning routing tables
Nov 27 02:25:50.136: BGP: topo INT:VPNv4 Unicast:base Scanning routing tables
Nov 27 02:25:50.443: BGP: topo global:IPv4 Multicast:base Scanning routing tables
Nov 27 02:25:50.513: %CPPDRV-3-LOCKDOWN: F0: cpp_cp: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Nov 27 02:25:51.134: %CPPDRV-3-LOCKDOWN: F0: fman_fp_image: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Nov 27 02:25:51.138: %CPPOSLIB-3-ERROR_NOTIFY: F0: fman_fp_image: fman-fp encountered an error -Traceback= 1#7f7880ed3dc8704ed91114536fcc31bf errmsg:7FDC3D85E000+1175 cpp_common_os:7FDC2C4B8000+D205 cpp_common_os:7FDC2C4B8000+D14E cpp_common_os:7FDC2C4B8000+1902E cpp_sbs:7FDC2BA23000+B0D7 cpp_sbs:7FDC2BA23000+7B72 cpp_sbs:7FDC2BA23000+76C2 cpp_sbs:7FDC2BA23000+75DE cpp_cef_mpls_common:7FDC2D4D5000+46C8F cpp_cef_mpls_common:7FDC2D4D5000+46871 :400000+44EB5D evlib:7FDC2FC14000+B379 evlib:7FDC2FC14000+DCD0 :
Nov 27 02:25:51.138: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_cp: cpp_cp encountered an error -Traceback= 1#39de1d244913e6640287a4369fbe1df2 errmsg:7F74E239D000+1175 cpp_common_os:7F74E5358000+D205 cpp_common_os:7F74E5358000+D14E cpp_common_os:7F74E5358000+1902E cpp_sbs:7F74EC2ED000+B0D7 cpp_sbs:7F74EC2ED000+85C6 cpp_sbs:7F74EC2ED000+8494 cpp_ipfrag_svr:7F74ECF76000+D45F cpp_ipfrag_svr:7F74ECF76000+7FA0 cpp_common_os:7F74E5358000+116AE cpp_common_os:7F74E5358000+110EA cpp_common_os:7F74E5358000+10F2B evlib:7F74E
Nov 27 02:25:55.851: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 10.2.31.209 (Port-channel1) is down: holding time expired
Nov 27 02:25:56.187: %TRACKING-5-STATE: 1 ip sla 1 state Up->Down
I think it looks like this problem:
http://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63764.html
Modules:
F0 ASR1000-ESP40 ok, active 32w4d
F1 ASR1000-ESP40 ok, standby 32w4d
If i upgrade ios to asr1000rp2-adventerprisek9.03.16.01a.S.155-3.S1a-ext.bin following by this instructions:
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/issu.html#56168
will i fix this errors?
(sorry for my english)
