12-20-2015 01:17 PM - edited 03-08-2019 03:10 AM
Hello all!
I am currently studying for my CCENT ICND1 and im attempting to aim to take my test at the end of january.
I am current 2, 2950 catalyst and 2, 2801 ISR cisco routers.
First im going to describe my issue.
I am somewhat familiar with the basic commands and ive configured my switches many times and erased the startup config for practice. I want you all to know due to personal reasons i was in situation where i was unable to access my equipment for 6 months. I have been watching CBT videos and Train signal videos, I also have the ICND 1\2 series books from Wendell Odom.
I am not sure if i a completely overlooking something completely obvious and missing it or if i forgot something.
I have reset my startup config several times because of the follow:
I am having an issue with my interfaces on my SWITCHES where when i issue the "no shutdown" command. The interface will no longer be admin. shut down. The state of the interface is DOWN and so is the protocol. This is only happening when i am attempting to turn this interface into a trunk port. Ive also tried to use both of my ports on both of my switches to use them as access ports.
I also am only using 1 vlan thats been "no shutdown" issued. since im using a layer 2 device
No matter what i try or do, the link just stays down as well as the protocol.
I tried zooming in on the interface incase anyone wanted to see but i dont think it will be much help.
I will also show you the IOS I am running.
i have used known working cables\reseated the cables and shut down and re enabled the interfaces. I also tried to put these ports into vlan 2 so they were not in the native vlan.
this is my first switch in interface 0/2
FastEthernet0/2 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 0014.f2c4.d602 (bia 0014.f2c4.d602)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input never, output 00:56:18, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
62 packets output, 7016 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
here is my 2nd switch on port 2
Hardware is Fast Ethernet, address is 0014.69b1.5e02 (bia 0014.69b1.5e02)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Last input never, output 00:57:42, output hang never
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
my first switch is setup the same way, the only difference is the IP in vlan 2. im using 10.1.10.1 instead.
ive also tried to do 10.1.1.1 and 10.1.1.2 for each device respectively.
hostname switch2
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
switchport access vlan 2
switchport mode trunk
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.1.1.2 255.255.255.0
no ip route-cache
interface Vlan2
ip address 10.1.10.1 255.255.255.0
no ip route-cache
shutdown
ip http server
line con 0
line vty 5 15
end
this is the IOS i am running
Current configuration : 1328 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
i am running 12.1 on both of my switches.
now the extremely odd thing is when i connect from my laptop to the switch via ethernet cable, the ports WILL work.
Is there anyone that might have an idea or tell what i did wrong?
Solved! Go to Solution.
12-20-2015 03:00 PM
Try using a crossover cable for the switch to switch connection. I don't think your 2950 supports auto-mdix
John
12-20-2015 03:00 PM
John
12-20-2015 04:08 PM
Thank you for the idea. My switch does the support this feature. However, i do not remember the Mdix being off by default. IT needed to be enabled in order to use a straight through. The Xover cable did work as well.
12-20-2015 04:19 PM
actually MDIX isnt supported. i do have to use a crossover.
