Cisco ASR1001-X port-channel
nyami.david
Beginner
Beginner
Hello everybody,
I am installing Cisco ASR1001-X with the software asr1001x-universalk9.16.03.04.SPA.bin.
Apparently it supports only 64 port-channels numbers (1- 64). I am connecting the router to a device with higher Port-channel numbers and I would  like the numbers to match. Is there anyway to extend this range on the device?
Cheers
David
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
David,
No, usually you can't extend the number of supported Portchannels. 1-64 is what you can use.
Thanks. That's what I suspected. But doesn't hurt to ask.
Grüße
David
Recognize Your Peers
