cisco ASR1004 error %VRF specified does not match existing router
fabio.marino
Hi all,
I have a problem and I really do not know the reason.
Simple scenario. I need to configure ospf into a ASR1004 router.
Here the command
vrf definition TEST-02
 address-family ipv4
 exit-address-family
interface Loopback25
 description TEST-02
vrf forwarding TEST-02
 ip address 1.1.1.1 255.255.255.255
 ip ospf 2 area 0.0.0.1
As soon I am running the command  ip ospf 2 area 0.0.0.1, I got this error %VRF specified does not match existing router.
I configure with success other different vrf before and after this problem so I can not understand why the router is refusing this configuration.
Any idea?
Thank you.
Fabio.
Hello.
Your OSPF process 2 (in global configuration mode) should be configured with vrf keyword like following:
 router ospf 2 vrf TEST-02
Levi502
I know this is years later but I seen this asked many times and only answered with a solution by Vasilii Mikhailovskii
or you could remove existing running ospf 2 process in global configuration, then add it under the interface as you have it.
themicgeinus
Another simple solution that worked for me, is reloading the router and tried the command again
