unknown protocol drops on CISCO C9300-48T switch
aprasad11
Hi All,
Need you help. I am getting "unknown protocol drops" error in my CISCO C9300-48T switch and i think this is causing some application issues.
Below is version and not sure if this is some sort of software bug.
BOOTLDR: System Bootstrap, Version 16.8.1r [FC4], RELEASE SOFTWARE (P)
HKSW000#show inter te 1/1/1
TenGigabitEthernet1/1/1 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is acf5.e6d5.2635 (bia acf5.e6d5.2635)
Description: dT: URCS - 10.170.124.10
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 32481000 bits/sec, 4951 packets/sec
5 minute output rate 55326000 bits/sec, 6761 packets/sec
7717719035 packets input, 6347542007358 bytes, 0 no buffer
Received 249027 broadcasts (245968 multicasts)
0 watchdog, 245968 multicast, 0 pause input
9993870483 packets output, 9455920391816 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
122382 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Leo Laohoo
Unknown protocol drop = DTP
Can be ignored.
I had disabled DTP cdp and vtp still drop shows
Unknown protocol drops are not bad.
If you really want it to remain "0" then disable Trunk.
