Cisco BGP Routes Not Appearing
Hello Experts,
Can someone please tell me why the route that I  have added to the BGP routing process won't appear in BGP when I issue  the show ip bgp command.
Please see attached logs...
Cheers
Carlton
smehrnia
Level 7
Level 7
hi,
im using a Mac so i couldnt see ur zip file, but in general, for a route to appear in bgp process, you should have it in ur routing table (dynamic or static). BGP is rather an application than a routing protocol which greately relys on IGP Routing protocols to operate.
Again, if the following conditions are not met, bgp wont operate correctly, so check if ur config is correct:
** BGP will not put routes that it cannot verify reachability for in the main IP routing table.
** For routers to successfully use BGP routes, they must always have a route to the next-hop IP address in the main IP routing table, (IGP Dependency).
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
JohnTylerPearce
Level 7
Level 7
Under your BGP configuration, I saw the following.
network 5.1.104.0 mask 255.255.248.0
Are you running a dynamic routing protocol? And if so, is the 5.1.104.0 network in your routing table?
I don't see a dynamic routing protocol configured in your configuration, so for you to advertise 5.1.104.0,
you will need to have a route for that in your routing table.
smehrnia
Level 7
Level 7
hi,
Soroush.
Hope it Helps!
Soroush.
