Cisco Business 350 Series Switch
pbiggs
Hello
Our organization has all Cisco routers and switches. In the past they had used after market switches in offices within our branches such as Netgear. I felt although this is needed it would be best to use a Cisco manageable switch and we purchased a 350 series switch. I like it but they are somewhat different as far as IOS from what I am used to.
I wanted to know if anyone has experience with this particular model of switch? We normally use ROAS in our environment and trunk for example on phone where the computer connect to the phone and the phone connects to the drop which connects to MDF. When trying this setup which works well with the 9300L, 3650's etc. there's no issue. It doesn't seem to grab an IP on the phone indicating bad router. The default gateway is listed in the config. Can you see an issue as to why this may be happening?
Thank you
Pete
0 Replies 0
