Cisco C867VAE-W-A-K9 i cant have wireless working !!!
Dr.X
Level 2
Level 2
dear support .
i have cisco router
Cisco C867VAE-W-A-K9   i wasn't able to find any documentation for wifi enable on forums .
hope to help me how to enable basic wifi  , just wifi with psk and bridged to my lan .
here is my router info below :
Branch1#sh inventory
NAME: "C867VAE-W-A-K9", DESCR: "C867VAE-W-A-K9 chassis, Hw Serial#: GMK200900AV, Hw Revision: 1.0"
PID: C867VAE-W-A-K9 , VID: V01 , SN: GMK200900AV
Branch1#
Branch1#sh version
Cisco IOS Software, C860 Software (C860VAEW-ADVSECURITYK9-M), Version 15.3(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 04-Aug-15 06:02 by prod_rel_team
ROM: System Bootstrap, Version 15.3(3r)M1, RELEASE SOFTWARE (fc1)
Branch1 uptime is 4 weeks, 21 hours, 15 minutes
System returned to ROM by reload at 10:48:51 UTC Thu Nov 3 2016
System image file is "flash:c860vaew-advsecurityk9-mz.SPA.153-3.M6.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C867VAE-W-A-K9 (revision 1.0) with 385024K/32768K bytes of memory.
Processor board ID GMK200900AV
1 DSL controller
1 Ethernet interface
3 FastEthernet interfaces
4 Gigabit Ethernet interfaces
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
131072K bytes system flash allocated
kind regards
10 Replies 10
Mark Malone
Have you seen this doc it goes through setting up wireless on a 800 series router
http://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_01001.html#con_1091378
and this one
http://www.cisco.com/en/US/docs/routers/access/800/880/software/configuration/guide/880_basic_device_wireless_config.html
i already tried all other options
none is working
Branch1(config)#service ?
alignment Control alignment correction and logging
call-home Enable call-home service
compress-config Compress the nvram configuration file
config TFTP load config files
counters Control aging of interface counters
dhcp Enable DHCP server and relay agent
disable-ip-fast-frag Disable IP particle-based fast fragmentation
exec-callback Enable exec callback
exec-wait Delay EXEC startup on noisy lines
finger Allow responses to finger requests
hide-telnet-addresses Hide destination addresses in telnet command
linenumber enable line number banner for each exec
nagle Enable Nagle's congestion control algorithm
old-slip-prompts Allow old scripts to operate with slip/ppp
pad Enable PAD commands
password-encryption Encrypt system passwords
prompt Enable mode specific prompt
pt-vty-logging Log significant VTY-Async events
sequence-numbers Stamp logger messages with a sequence number
slave-log Enable log capability of slave IPs
tcp-keepalives-in Generate keepalives on idle incoming network connections
tcp-keepalives-out Generate keepalives on idle outgoing network connections
tcp-small-servers Enable small TCP servers (e.g., ECHO)
telnet-zeroidle Set TCP window 0 when connection is idle
timestamps Timestamp debug/log messages
udp-small-servers Enable small UDP servers (e.g., ECHO)
Branch1(config)#service mo
Branch1(config)#service-module wlan-ap 0 session
% Invalid input detected at '^' marker.
Branch1(config)#interface Dot11Radio 0
Branch1(config)#
Branch1(config)#do sh ip int b
ATM0 unassigned YES NVRAM administratively down down
Dialer0 unassigned YES unset up up
Dialer1 xxxxx YES IPCP up up
Ethernet0 unassigned YES NVRAM up up
FastEthernet0 unassigned YES unset down down
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset down down
GigabitEthernet0 unassigned YES unset down down
GigabitEthernet1 unassigned YES unset down down
GigabitEthernet2 unassigned YES NVRAM administratively down down
NVI0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Vlan1 10.35.90.254 YES NVRAM up up
Wlan-GigabitEthernet0 unassigned YES unset up up
Branch1(config)#
can you give me direct config to my router ??
I see you have a wlan interface , see section Starting a Wireless Configuration Session
Note Before you configure the wireless settings in the router's setup, you must follow these steps to open a session between the router and the access point.
Enter the following commands in global configuration mode on the router's Cisco IOS CLI.
SUMMARY STEPS
1. interface wlan-ap0
2. ip address subnet mask
3. no shutdown
4. interface vlan1
5. ip address subnet mask
6. exit
7. exit
8. service-module wlan-ap 0 session
DETAILED STEPS
Branch1(config)#int Wlan-GigabitEthernet0
Branch1(config-if)#ip ad
Branch1(config-if)#ip add
Branch1(config-if)#ip address 10.35.90.253 255.255.255.0
% IP addresses may not be configured on L2 links.
Branch1(config-if)#
Ok this looks a bit closer its needs to be a trunk for that specific interface as below
do a  ctrl f on the page and search for ....Configure the wlan-GigabitEthernet0 interface as a trunk
http://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/virtual-office/white_paper_c11-492842.html
Two additional interfaces exist that are used to communicate with the access-point module: wlan-ap0 and wlan-GigabitEthernet0. You must configure the wlan-ap0 interface with an IP address (any private IP address works; check RFC 1918 for available private subnets) in order to allow reverse Telnet from the router to the access-point module:
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address <wlanap0-ip-address> 255.255.255.255
arp timeout 0
As mentioned earlier, one advantage of having the access-point module is that it can be deployed in both modes: autonomous (standalone), and lightweight (unified). In lightweight mode, the access point associates with a WLAN controller and downloads its configuration file from there. Thus you must do all necessary configuration for secure wireless access on the controller. In autonomous mode, the configuration is entered on the access point itself, without using a WLAN controller in the middle. The following command is used on the router to define the mode of operation of the access point:
service-module wlan-ap 0 bootimage autonomous, for autonomous mode
service-module wlan-ap 0 bootimage unified, for lightweight mode
Autonomous Mode
Configure the wlan-GigabitEthernet0 interface as a trunk in order to allow traffic from multiple VLANs to pass onto the access point:
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
switchport trunk native vlan 10
i still don't see that interface (((wlan-ap0)))
i already configured the interface ((wlan-GigabitEthernet0)) as trunk .
im not sure what to do next !!!
here is config that i have :
Branch1#sh ip int b
Dialer1 115.70.45.124 YES IPCP up up
Branch1#sh run int Wlan-GigabitEthernet0
Building configuration...
Current configuration : 179 bytes
no ip address
end
Branch1#
thank you for great response
This is a step by step guide using the wlan-G0 you could try that
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/825-cisco880w-multiple-ssid.html
i appreciate your kind help .
but again
service-module cmd is not allowed on my  router !
Branch1(config)#
also i don't see the interface Dot11Radio0 when i do ,
#sh ip int b
what do you think  for this issue ??
can you help ?
