Cisco C9300P-48 PoE Question
mdieken011
I have a stack of 4 C9300P-48 switches.  I have them power stacked also.  The switches available power differs between them.  My question is why?  Below is the "show power inline" output.
Module   Available   Used Remaining
               (Watts)   (Watts)   (Watts)
1             935.0      183.2      751.8
2             1440.0     326.6     1113.4
3             1055.0     333.6     721.4
4             1440.0     319.4     1120.6
I've seen similar issues in out 9300s, and also noticed on your output is does not show switch 3 power supplies .
7 Replies 7
balaji.bandi
Can you post below output.
show version
show modules
show switch
show inventory.
BB
login as: mrhadmin
Using keyboard-interactive authentication.
Password:
WC10-SJW>en
Password:
WC10-SJW#show ver
Cisco IOS XE Software, Version 16.06.04a
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.6.4a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 26-Oct-18 18:15 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.8.1r [FC4], RELEASE SOFTWARE (P)
WC10-SJW uptime is 14 weeks, 5 days, 22 hours, 26 minutes
Uptime for this control processor is 14 weeks, 5 days, 22 hours, 28 minutes
System returned to ROM by PowerOn
System restarted at 14:33:56 CST Thu Jan 17 2019
System image file is "flash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Permanent network-advantage
dna-advantage Subscription dna-advantage
cisco C9300-48P (X86) processor with 1392681K/6147K bytes of memory.
Processor board ID FCW2240E0YH
2 Virtual Ethernet interfaces
208 Gigabit Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
8 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
1638400K bytes of Crash Files at crashinfo-2:.
11264000K bytes of Flash at flash-2:.
1638400K bytes of Crash Files at crashinfo-3:.
11264000K bytes of Flash at flash-3:.
1638400K bytes of Crash Files at crashinfo-4:.
11264000K bytes of Flash at flash-4:.
Base Ethernet MAC Address : 70:35:09:6d:4c:80
Motherboard Assembly Number : 73-18274-04
Motherboard Serial Number : FOC22388UA5
Model Revision Number : A0
Motherboard Revision Number : A0
Model Number : C9300-48P
System Serial Number :
Switch Ports Model SW Version SW Image Mode
* 1 62 C9300-48P 16.6.4a CAT9K_IOSXE INSTALL
2 62 C9300-48P 16.6.4a CAT9K_IOSXE INSTALL
3 62 C9300-48P 16.6.4a CAT9K_IOSXE INSTALL
4 62 C9300-48P 16.6.4a CAT9K_IOSXE INSTALL
Switch 02
Switch uptime : 14 weeks, 1 day, 3 hours, 11 minutes
Base Ethernet MAC Address : 70:35:09:35:08:00
Motherboard Serial Number : FOC22388TM7
System Serial Number : FCW2240E0Y2
Switch 03
Switch uptime : 14 weeks, 3 hours, 4 minutes
Base Ethernet MAC Address : 70:35:09:0e:ae:80
Motherboard Serial Number : FOC2237358C
System Serial Number : FOC2240Q0WP
Switch 04
Switch uptime : 13 weeks, 6 days, 23 hours, 1 minute
Base Ethernet MAC Address : 70:35:09:6d:47:80
Motherboard Serial Number : FOC2237358H
System Serial Number : FOC2240Z0QE
Configuration register is 0x102
WC10-SJW#show modules
% Invalid input detected at '^' marker.
WC10-SJW#show mod?
module
Switch Ports Model Serial No. MAC address Hw Ver. Sw Ver.
1 62 C9300-48P XXXXXXXXXXX 7035.096d.4c80 V02 16.6.4a
2 62 C9300-48P FCW2240E0Y2 7035.0935.0800 V02 16.6.4a
3 62 C9300-48P FOC2240Q0WP 7035.090e.ae80 V02 16.6.4a
4 62 C9300-48P FOC2240Z0QE 7035.096d.4780 V02 16.6.4a
WC10-SJW#show switch
Switch/Stack Mac Address : 7035.096d.4c80 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 7035.096d.4c80 15 V02 Ready
2 Standby 7035.0935.0800 1 V02 Ready
3 Member 7035.090e.ae80 1 V02 Ready
4 Member 7035.096d.4780 1 V02 Ready
WC10-SJW#show inv
NAME: "c93xx Stack", DESCR: "c93xx Stack"
PID: C9300-48P , VID: V02 , SN: FCW2240E0YH
NAME: "Switch 1", DESCR: "C9300-48P"
NAME: "StackPort1/2", DESCR: "StackPort1/2"
PID: STACK-T1-50CM , VID: V01 , SN: MOC2237A4U4
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-1100WAC , VID: V02 , SN: DTN2230V1CT
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-715WAC , VID: V03 , SN: LIT223525NK
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "8x10G Uplink Module"
PID: C9300-NM-8X , VID: V01 , SN: FOC22395NYD
NAME: "Te1/1/8", DESCR: "1000BaseSX SFP"
PID: , VID: , SN: 9327570550
NAME: "Switch 2", DESCR: "C9300-48P"
PID: C9300-48P , VID: V02 , SN: FCW2240E0Y2
NAME: "StackPort2/1", DESCR: "StackPort2/1"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2235G16M
NAME: "StackPort2/2", DESCR: "StackPort2/2"
PID: STACK-T1-50CM , VID: V01 , SN: MOC2235A6EM
NAME: "Switch 2 - Power Supply A", DESCR: "Switch 2 - Power Supply A"
PID: PWR-C1-1100WAC , VID: V02 , SN: DTN2230V1CR
NAME: "Switch 2 - Power Supply B", DESCR: "Switch 2 - Power Supply B"
PID: PWR-C1-715WAC , VID: V03 , SN: LIT223525LK
NAME: "Switch 3", DESCR: "C9300-48P"
PID: C9300-48P , VID: V02 , SN: FOC2240Q0WP
NAME: "StackPort3/1", DESCR: "StackPort3/1"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2235G0T8
NAME: "StackPort3/2", DESCR: "StackPort3/2"
NAME: "Switch 4", DESCR: "C9300-48P"
PID: C9300-48P , VID: V02 , SN: FOC2240Z0QE
NAME: "StackPort4/1", DESCR: "StackPort4/1"
NAME: "StackPort4/2", DESCR: "StackPort4/2"
NAME: "Switch 4 - Power Supply A", DESCR: "Switch 4 - Power Supply A"
PID: PWR-C1-1100WAC , VID: V02 , SN: DTN2230V199
NAME: "Switch 4 - Power Supply B", DESCR: "Switch 4 - Power Supply B"
PID: PWR-C1-715WAC , VID: V03 , SN: LIT223526R5
NAME: "Switch 4 FRU Uplink Module 1", DESCR: "8x10G Uplink Module"
PID: C9300-NM-8X , VID: V01 , SN: FOC22395JTQ
NAME: "Te4/1/8", DESCR: "1000BaseSX SFP"
PID: , VID: , SN: 9327570555
WC10-SJW#
balaji.bandi
As per inventory show correctly where do you see wrong ? ( i did not see your Switch PSU in the list dont know why ?)
can you post switch stack information or RPC information to verify.
BB
I believe it has something to do with stack power.  I am currently researching it and can post more later.
It turns out that switch #3 power supply is bad.  Thanks for the help.
Leo Laohoo
Upgrade the firmware first.
The version currently used is a "re-build".
