Cisco C9500 PSU Issue
Roy Sandy
Hi everyone
I have a C9500 Stack Switch with IOS Version 16.12.1[FC2] & 2x650W PSU C9K-PWR-650WAC-R. There was once a case where one PSU went off, the HW of the device was still on but all the connections and links were down. The question is, why is this happening, isn't a redundant PSU?
based on screenshot we are are not sure how many PSU you have, show modules and show evniron show us more information
what mode PSU configured redundant ? Also this is SVL - so is the PSU x 2 installed on both the switches ? ( so totaly 2 PSU ?)
Note : 16.12.X code has many bugs those all resolved in 17.3.6 or 17.6.4 to upgrade.
BB
9 Replies 9
Mark Elsen
                               >...There was once a case...
       - Difficult to backtrack on what happened exactly , perhaps other factors were involved too (e.g.). Best is to always have a syslog server configured on the C9500 (stack) so that device logs can always be reviewed  , also during production stages (e.g.). Flexible options are usually available to archive logs too (on the syslog server)  and go back in time  for log analysis , if needed ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
thankyou for response
you can see the log bellow:
BB
how i check redundant mode?
You can see detail device inven bellow:
If you have logs, can you post all the logs form the start to end (in TEXT file no SCREENSHOT)
also upgrade highly suggested to to repeat that issue again.
BB
                                                  >...how i check redundant mode?
   Ref : https://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/220196-troubleshoot-power-supplies-on-catalyst.pdf , checkout the document mode as how to set power supplies in redundant mode or not and how to verify the settings ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
4 supplies in 2 9500-48y4C SVL, lost a single supply in one of the 9500's
Lanman70
Had similar issue, UPS failure on one of the pwr supplys, all glc-t ports started up/down remained until power was restored to down supply.   TAC wanted to send a replacement psu, said i should run with both supplies.
Roy Sandy
@Mark Elsen @balaji.bandi thanks for your prompt response and advice. It seems that due to a bug in the ios 16.2 version, I will upgrade it
