02-22-2023 11:33 PM
Hi there,
I want to check and verify all the configuration of a Cisco Catalyst 2960+ what commands do you suggest to use to view and print all the config info on such a Switch? Thank you for your help!
02-22-2023 11:37 PM
show run all (show you hidden config also)
02-23-2023 03:01 AM - edited 02-23-2023 03:08 AM
thank you
how do you login using macos /terminal /new remote connection with hostname and password?
I only have the hostname and password, what would be the "user"? (user @ hostname )
02-24-2023 06:06 PM
ssh user@deviceip
then you get to accept - y or yes to accept.
enter the password to login
Note : I expect you made configuration on the switch for ssh connection config.
