Cisco catalyst 4500e rebooted unexpectedly
m_ashok89
Dear team,
we are facing problem in cisco catalyst switch, actually we are using Cisco catalyst 4500e switch, Two month back we upgrade IOS from "cat4500e-ipbasek9-mz.150-2.SG" to cat4500e-ipbasek9-mz.152-2.E1.bin “since i upgrade new IOS that  was running perfectly,  but last two weeks back unexpectedly switch was rebooted and today also we faced the same problem. here i enclosed the tech support details. kindly check and suggest me the correct solution.
  Is there in any bug is there?...... How can we clarify whether the switch is ok on that IOS.....
 please suggest me the right IOS image for my cisco catalyst 4500e switch
This seems to be hitting the bug
https://tools.cisco.com/bugsearch/bug/CSCuq71667/?reffering_site=dumpcr
Madhu.
Hi Ashok,
Looks 15.2.2E2 has the fix. you could try upgrading to it.
Hope this helps.
Please do remeber to rate all useful posts.
Madhu.
Do you require any further support?
This document explains the step-by-step procedure to upgrade the software image on Catalyst 4500/4000 series switches that run CatOS on Supervisor I and II modules, Cisco IOS® on 4232-L3 module, and Cisco IOS on Supervisor III, IV, and V modules. The software image upgrade is necessary for these reasons: Implement new features in your network which are available in new software releases. Install a new line card that is not supported by the current software version you run on the switch. Fix a known bug that affects your switch if the bug is resolved in the future software release. https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/27848-179.html.
