Cisco Catalyst 4948 Switch - Which Model ?
smhughes55
Hi there,
I am trying to establish what model of Cisco 4948 I have. Whether it's the the standard WS-C4948, WS-C4948-S or the WS-C4948-E. The "show ver" lists the model as WS-C4948 however the unit has dual power supplies and is running the Enterprise Services image. According to this Cisco Bulletin it would be classed as the WS-C4948-E http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/product_bulletin_c25-552113.html.
Could it be that the "show ver" doesn't differentiate between the different variants,  it just list the platform as a 4948
5 Replies 5
Jon Marshall
smhughes55 wrote:
Hi there,
Scott
Have a look at Table 8 in the 4948 datasheet -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/product_data_sheet0900aecd8017a72e.html
Basically if you are running Enterprise Services image it is the 4948-E and if you are running IP Base it is 4948-S. All 4948 switches have dual power supply capability.
Jon
sachinraja
Level 9
Level 9
HI Scott
Just to add to what Jon wrote :
You would use a combination of Show version, show module, and show bootflash: to determine your model/IOS.
show module - would show the chassis type as WS-C4948
Show bootflash would give the IOS you are running:
1) With EWA series, you would have the following options:
cat4000-i5k91s-mz.122-25.EWA14.bin --- shows an enhanced version (i5) ---> so this would be WS-C4948E
cat4000-i9k91s-mz.122-25.EWA14.bin -- shows a basic version (i9) --> WS-C4948S
2) With other SG Versions, the IOS naming is self-descriptive:
cat4500-entservices-mz.122-53.SG1.bin  - Enterprise services
cat4500-ipbase-mz.122-53.SG1.bin  - IP BASE
cat4500-lanbase-mz.122-53.SG1.bin  - LAN BASE
Based on what you have on your switch, you will be able to determine the base version of the device.
Hope this helps.. all the best..
Raj
glen.grant
   Try show idprom supervisor ....
The Cisco Configurator Tool shows the following models:
WS-C4948      Catalyst 4948, optnl sw, 48-Port 10/100/1000+4 SFP, no p/s     USD 7,995.00
WS-C4948-S      Catalyst 4948, IPB s/w, 48-Port 10/100/1000+4 SFP, 1 AC p/s     USD 10,495.00
WS-C4948-E      Catalyst 4948, ES s/w, 48-Port 10/100/1000+4 SFP, 1 AC p/s     USD 14,495.00
WS-C4948E      Catalyst 4948E, opt sw, 48-Port 10/100/1000+ 4 SFP+, no p/s     USD 10,495.00
WS-C4948E-S      Catalyst 4948E, IPB, 48-Port 10/100/1000+ 4 SFP+, AC p/s     USD 12,995.00
WS-C4948E-E      Catalyst 4948E, ES, 48-Port 10/100/1000+ 4 SFP+, AC p/s     USD 16,995.00
What is the difference between WS-C4948 and WS-C4948E (not WS-C4948-E)?  Is this Enhanced?  Cisco.com does not display any information about 4948E.  Also, a chat with a Cisco person could not answer this question.
It looks like the WS-C4948Es support SFP+, which is a new 10Gbps SPF module.  I would assume since this is a hardware difference that you should be able to tell whether your switch is a regular 4948 or a 4948E through the "show module" command, but I haven't seen testing documents for a 4948E to confirm.
