cisco Catalyst 9200 smart licesnse activion
Mustapha Bassim
Hello Dears
I am trying activation Cisco Catalyst 9200 switch but the command
license smart register idtoken XXXXXXX
but the command is not include "register"
so anyone could help plz ?
6 Replies 6
Leo Laohoo
If the switch is on 17.3.2 (and newer), there is no need to that.  The switch is automatically "enrolled" to CSL.
Hi dear and thnx for your reply , the Version is17.3.4b and in license portal it's still give me it's not used
Post the complete output to the command "sh license status".
here it's
MGMT-Switch#show license status
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Smart
URL: https://smartreceiver.cisco.com/licservice/license
Proxy:
Not Configured
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Jun 25 13:01:43 2022 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Mar 31 13:55:56 2022 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
balaji.bandi
post the config here, there are a couple of ways to register. but if the device already registered with perpetual you are ok:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-3/configuration_guide/sys_mgmt/b_173_sys_mgmt_9200_cg/cisco_smart_licensing_client.html
BB
