Cisco Catalyst 9300 with different model can be Stacking?
inamsiddiqui
Kindly guide me Cisco Catalyst 9300 Series with different model switches can be stacking? e.g., C9300-24P-A can stack with C9300-24T-A?
Leo Laohoo
Can be done:
  • All stack members must be running the same, exact IOS-XE version.
  • All stack members must be running the same "mode":  Install Mode OR Bundle Mode (and not a mix of both)
To stack them, follow the proceedure:
  1. Leave the stack master powered on.
  2. Power OFF the stack member.
  3. Attach the stacking cable.
  4. Power up the stack member.
  5. Wait for the two left-most LED lights to go SOLID ON (and not blinking)
  6. Connect the next stack member's stacking cable.
  7. Power up the next stack member.
  8. Repeat #5
IMPORTANT:
After all stack members are powered up and have joined the stack, do not forget to configure the "priority" (in Enable Mode).
Leo Laohoo
Can be done:
  8. Repeat #5
IMPORTANT:
balaji.bandi
These model can be stack together ( only not possible Cat 9300 and Cat 9300L)
how to connect and make stack good step by step document :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
BB
