Cisco Catalyst 9500-40X Fans Included or not??
t.zelenik
I am trying to quote a Cisco Catalyst 9500-40X-A switch for a customer and the datasheet is unclear as to whether or not I need to include (5) of the FAN-T4-R= modules. I opened a PDI ticket and they said that the power supplies have fans built in and I can order the FAN-T4-R= modules...but they didn't tell me if they are required or not. Thanks in advance!
Reza Sharifi
See table-15 in this link.
The chassis comes with 2 power supplies and build in fans.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9500-series-switches/data_sheet-c78-738978.html
So they fans that are built into the power supplies are sufficient to cool the system under normal operations, correct? Meaning I do not have to order the fan modules - they are completely optional.
The fans are built-in and come with the switch. If you look at the picture in the link I posted, the switch comes with 2 PSUs and 4 or 5 fan trays.
