CPU
Robo123
I have a 4506 switch running " cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin" where we are getting high cpu.
Core 0: CPU utilization for five seconds: 19%; one minute: 28%; five minutes: 33%
Core 1: CPU utilization for five seconds: 94%; one minute: 65%; five minutes: 58%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
4590 237289 27421279 294 56.39 46.38 45.21 0 iosd
4544 2857663 33687667 212 0.36 0.33 0.33 0 ffm
7 146605 6044430 24 0.04 0.01 0.03 0 sirq-net-rx
Please help to resolve the issue.
7 Replies 7
Julio E. Moisa
It could be a bug, an upgrade could be required, I suggest open a case with the Cisco TAC, to analize the device, please check this link:
https://supportforums.cisco.com/t5/lan-switching-and-routing/iosd-process-getting-50-cpu-utilization/td-p/2235501
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
can you share the bug id same time i have another device "cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin"running in latest IOS .
Please Suggest on the above.
Hello
Can you post
show process cpu sorted | ex 0%
res
Paul
Kind Regards
Paul
If one gets high CPU and the process causing this is "iosd", this normally means that the supervisor card is being hammered by downstream clients pushing too much data.  To find out which ones they are, just look at the interface counters with very high Total Output Drops.
1- Below you can find a simple guide to troubleshoot on the most common causes of high CPU in the 4500 platform just in case you need it for future reference.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
2- Kindly check in the logs if there are any logs pointing to any routing protocols flaps/ HSRP flaps/MAC addres flaps?
3- If any issues see when the routes are unreachalbe refer the following bug :CSCua99861 (
High CPU identified attributed to L3 Glean packets coming in from a couple of print servers sending packets to unknown destinations and after shutting them down, the CPU had dropped down).
4-Further more to determine the root cause we would need the following information:
- show version, show module
- show process cpu history
- show processes cpu sorted
- show processes cpu detailed process iosd sorted
- show platform health
- show platform cpu packet statistics
- show platform cpu packet statistics all
- show platform cpu packet buffered
- show ip traffic
