Cisco Catalyst IP DEVICE TRACKING
marcomerati
Hi to all,
I've enable ip device tracking on some ports with these commands
Switch(config)# ip device tracking
Switch(config)# interface fastEthernet 4/3 or Gigabitethernet 1/0/48  ecc
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 1  (vlan name)
Switch(config-if)# ip device tracking maximum 5
Switch(config-if)# ip verify source tracking
Switch(config-if)# end
Everything is working but I can enable only one by one port.
I would like to know if it's possible to enable ip device tracking on all ports of the switch at once
Thanks in Advance
rfalconer.sffcu
Level 3
Level 3
Can you apply using the interface range command? This will apply commands to all the interfaces defined.
interface range fas4/1 - 48
or
interface range gig1/0/1 - 48
rfalconer.sffcu
Level 3
Level 3
or
