10-09-2024 09:09 AM
Hi!
I am trying to configure ISE setting and when it comes to insert the radius password I am receiving the below error:
encrypted radius-server host 192.168.1.2 key 7 143542050805263F75
OR
encrypted radius-server host 192.168.1.2 key 143542050805263F75
OR
encrypted radius-server host 192.168.1.2 key ORIGINAL KEY(not encrypted)
Error: % Decryption of encrypted value has failed
Any tip?
Solved! Go to Solution.
10-09-2024 02:55 PM
The issue is that when using the "encrypted radius-server host" configuration command the system expects the MD5, ie. Type5 encrypted key NOT Type7 ("weak" encryption). So you should either supply Type5 encrypted key for the above command or use the "radius-server host" command.
Best regards,
Antonin
10-09-2024 12:04 PM
are you trying from command line ? what code running on the device, have you tried from GUI ?
we have test switch installed that worked for me sure.
10-09-2024 01:15 PM
Thanks for your attention.
I have only cli access at the moment and the version is shown below:
sh ver
Active-image: flash://system/images/image_cbs_ros_3.4.0.17_release_cisco_signed.bin
Version: 3.4.0.17
MD5 Digest: 28587fc679ea6d83371f12955cf20caa
Date: 29-Nov-2023
Time: 17:21:25
Inactive-image: flash://system/images/image1.bin
Version: 3.2.1.1
MD5 Digest: 937212ebf51de43330b6f7967a7445ae
Date: 13-Feb-2023
Time: 01:12:59
thanks
10-09-2024 02:55 PM
Best regards,
Antonin
10-10-2024 07:16 AM
it works!
Thank u soo much Antonin.
10-10-2024 12:58 PM
Thanks for the update: well done. Please beware of the Type 7 encryption (B0ndalt1).
Best regards,
Antonin
