Cisco CBS350 SNMP issue
ivanjaram007
Hi all,
I have issues setting up SNMP v2c on CBS350. I've been following instructions from Cisco official site (https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-/snmp-commands.html), but I can't set it up for the collector to see it.
Reading the instructions I did not see that an ACL allowing SNMP collector IP is necessary like when setting up SNMP on Cisco Catalyst series (which work flawlessly with the same collector, added quite a few to the collector).
Am I misssing something or are instructions in some way misleading?
Thanks in advance,
Ivan
balaji.bandi
what is the firmware running on Switch for now ;
check the config guide simple process not complicated (since you mentioned you did catalyst switches its same as it is)
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2777-configure-simple-network-management-protocol-snmp-communities-cbs.html
Note: before you do any ACL kinda, just make a simple config and run snmpwalk from your NMS is that works ?
also, the MIB download required more features to work for CBS.
BB
Mark Elsen
                      - What CLI command did you try ?
 M.
snmp-server community XXXXXXXX ro YYY.YYY.YYY.YYY
snmp-server source-interface traps vlan XXX
snmp-server host YYY.YYY.YYY.YYY 2c XXXXXXX
 - Verify if your settings can work by for instance adding or replacing  YYY.YYY.YYY.YYY  by a simple linux host address  (snmp client) and try an snmpget (example , with v2c) to the CBS350 ,also check the (snmp related) logs on your snmp manager when it is trying to query the CBS, which applies to the CBS itself too for both cases ,
 M.
balaji.bandi
BB
