Cisco CE500 switch, GUI configuration save
Clem58
Level 3
Level 3
I'm working on old switches Cisco CE500, I know we can configure it with 2 manners, GUI and GUI CLI.
For GUI CLI I've seen the "write" command, and I beleive we can "wr" the config we make with GUI CLI like that, like if we were working on a "real" CLI.
BTW, when you are working on the "only GUI" configuration, I cannot see any 'save configuration' on the graphical interface, does that mean the configuration is saved each time you make a modification ?
Thanks by advance,
balaji.bandi
its been long time i made my hands dirty with CEBoxes.
As i remember correctly they save automatically as soon as you click(modify) -
worth do small change in the GUI and check is that save ?
here is reference guide.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-express-500-series-switches/70485-cat-exp-500-config.html
BB
Not easy to test, as we have to restart a switch to confirm, and they are in production. By the way, thanks for your answer and help.
