Cisco Console Password Level
QUARK TARO
Level 3
Level 3
On cisco devices I have set password is below but this is not a strong password, anyone can decrypt it because it's level 7. How can I set more stronger encryption for console password?
line con 0
password 7 043B321C455B1E1B1D
Hello
As its a type 7 password you should be able to-  Use this
Kind Regards
Paul
My question is, I do not want to use type 7 password, is there a way to set more stronger encryption level for console?
Generally Console connection used, when you lost access to device connect over network.
If the Physicall security compromise person can reach with console access, what security works here ?
You can use external authentication for console more secure, but that is not best practice.
BB
Hello
Yes you can use the local D/B of the rtr , Create a local user with type 9 hasing (if supported) and apply AAA locally
Example
conf t
username xxx algorithm-type scrypt secret xxxx
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default local if-authenticate
aaa authorization console
Note: The above is only for local authentication, no central access control is being called upon,if you are currently using that then please post your exisiting configuration before applying the above.
Kind Regards
Paul
