CISCO device throughput test
chamaraw07
hi Guys
is there a way for us t run a throughput test on a CISCO switch port (trunk or access)
appreciate any help , thanks
saif musa
Level 9
Level 9
Use the command ( sh ip int sum ) for any port regardless of its being access or trunk.
Hope that could help
5 Replies 5
saif musa
Level 9
Level 9
Mark Malone
Run an Iperf test between two pcs connected on either side of the trunk or access link
Example
https://supportforums.cisco.com/document/12068771/iperf-test-measuring-throughputspeed-wlan-client
Joseph W. Doherty
What exactly are you trying to test/measure?
Reason I ask, generally any Cisco switch can support L2 wire-rate for any one of its ports, regardless of port's mode.
Hi Joseph
we want measure the throughput on 2 devices ,
1 . throughput of a trunk link between 2 switches over a 24 hour time frame
2 . throughput of the LAN port (gig) of a router over a 24 hour time frame
