Cisco IE-3300-8U2X-E
M R
Dear Experts,
How many PoE or PoE+ ports in Cisco IE-3300-8U2X-E?
This is an excerpt from the FAQs:
IE-3300-8U2X – This model is expandable. It has 2 10Gig SFP ports and 8 Copper Gigabit Ethernet ports on the base with PoE/PoE+, UPoE (60W 802.3bt type 3). Because it is expandable, the number of additional ports can be increased by 4, 8 or 16 with a 4 port, 8 port or 16 port IEM 3300 module. It can support up to 16 PoE+ ports, or 4 90W PoE (802.3bt type 4) ports with the proper Power supply.
IE: all 8 copper ports at your box should be PoE/PoE+ capable.
You can check above as per beneath:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3200-rugged-series/q-and-a-c67-741696.html
The same information can also be found also at the Hardware installation guide:
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3X00/Hardware/installation/guide/b_ie3x00_hig/b_ie2k-ip67-hig_chapter_01.html
(Please do not feel confused by the "4PPoE" phrase quoted at some Cisco docs - this is just another term for PoE++ or IEEE 802.3bt)
Best regards,
Antonin
Reza Sharifi
Hi there,
I am sure it has PoE ports, the qs is 8 or 4 ports?
Best regards,
Antonin
