Cisco IOS Image 12.2(25)EZ for etherswitch module for 2821 router
arumugasamy
Dear Netpros,
I am searching the cisco site to download this image for the 2821 router to resolve the IPT POE issue but I can not find anywhere in the site.
I did login using CCO ID provided. The etherswitch NM pre-requisites shows that we have to use this 12.2(25)EZ image for the switch module to provide POE to the IP Phones.
Arumugam.
krishnakumarr
Can you provide me the part number for ether switch module and current show ver on 2821 router
regards
krishna
krishnakumarr
regards
krishna
Kumar,
The part of the module is
NME-X-23ES-1G-P
I attached the sh ver of Host Router as below and also at the end attached the sh ver for the etherswitch module.
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(22)YB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 07-Aug-09 14:42 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
R1BAHRAINz uptime is 3 days, 20 hours, 35 minutes
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.YB4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 243712K/18432K bytes of memory.
Processor board ID FHK1249F1ZY
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
The below attached is the sh ver of Etherswitch module
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 08:46 by yenanh
Image text-base: 0x00003000, data-base: 0x00EE3E54
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)EZ, RELEASE SOFTWARE (fc1)
S1BAHRAINz uptime is 1 day, 23 hours, 22 minutes
System restarted at 18:34:20 UTC Thu Apr 20 1905
System image file is "flash:c3750-ipbase-mz.122-25.SEE2/c3750-ipbase-mz.122-25.SEE2.bin"
cisco NME-X-23ES-1G-P (PowerPC405) processor (revision 3.0) with 118784K/12280K bytes of memory.
Processor board ID FOC11131CZ5
Last reset from power-on
1 Virtual Ethernet interface
23 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1B:54:BB:15:00
Motherboard serial number       : FOC11131CZ5
Model revision number           : 3.0
System serial number            : FOC11131CZ5
Top Assembly Part Number        : 800-25011-01
Top Assembly Revision Number    : N/A
Version ID                      : V01
Hardware Board Revision Number  : 0x00
Switch   Ports  Model              SW Version              SW Image
*    1   25     NME-X-23ES-1G-P    12.2(25)SEE2            C3750-IPBASE-M
ghyacin
Where is this image located please?
