Cisco ISR4331 VLAN interface errors on startup
p_atkinson
Visitor
When I boot up my ISR4331/KP router I get the below Invalid input error messages
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FLM2147W0SR
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
interface Vlan1
% Invalid input detected at '^' marker.
no ip address
% Incomplete command.
shutdown
SETUP: new interface Vlan1 placed in "shutdown" state
I'm sure I can ignore the message and it won't interfere with the operation of the router but inquiring minds have to know.
The odd part is if I run the command "sh int" on the router I see a Vlan interface
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is ISR4331-3x1GE, address is 0027.900e.f4b0 (bia 0027.900e.f4b0)
  Internet address is 192.168.1.251/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is RJ45
  output flow-control is off, input flow-control is off
  Last input 00:00:00, output 00:00:37, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 19000 bits/sec, 13 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     706171 packets input, 189940008 bytes, 0 no buffer
     Received 312165 broadcasts (0 IP multicasts)
     0 watchdog, 393574 multicast, 0 pause input
     1425 packets output, 472606 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     5530 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0/1 is administratively down, line protocol is down
  Hardware is ISR4331-3x1GE, address is 0027.900e.f4b1 (bia 0027.900e.f4b1)
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
GigabitEthernet0/0/2 is administratively down, line protocol is down
  Hardware is ISR4331-3x1GE, address is 0027.900e.f4b2 (bia 0027.900e.f4b2)
  Full Duplex, 1000Mbps, link type is auto, media type is unknown media type
GigabitEthernet0 is administratively down, line protocol is down
  Hardware is RP management port, address is 0027.900e.f53f (bia 0027.900e.f53f)
  Keepalive set (10 sec)
  Auto Duplex, Auto Speed, link type is auto, media type is RJ45
Vlan1 is administratively down, line protocol is down
  Hardware is Ethernet SVI, address is 0027.900e.f534 (bia 0027.900e.f534)
     0 output errors, 2 interface resets
If I try to configure the interface I get the same type of message.
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int Vlan1
Below is the sh hard results
Router#sh hard
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 32 minutes
Uptime for this control processor is 33 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             None             None             None
securityk9       None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
Any assistance would be greatly appreciated
Thank You
Paul
ysotocob
It is possible that your device is missing the Switch module.
Confirm that on the inventory of the device.
This document can help you to configure SVI on ISR4000 router:
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/eesm/software/configuration/guide/4451_config.html#pgfId-1073928
7 Replies 7
Reza Sharifi
I think you may be hitting a bug.  No vlan should be present on this platform. I would open a ticket with Cisco and have them take a look at it. They probably recommend an IOS upgrade.
I felt the same way but even though the router is brand new and I've stated to Cisco I only want information on the error they refuse to talk to anyone unless the router has a smartnet contract.
If the router is brand new, you get one-year warranty and support by default. So, you should be able to open a ticket.
I finally reached someone at the support desk that would allow me to open a case without just sending me a router. Thank you for your help.
ysotocob
I was able to finally get a ticket open with Cisco and was told I need to install NIM-ES2-8-P card to get rid of the VLan interface errors.
Oleksandr Y.
Level 2
Level 2
The router does not seem to be aware that it should interact / have Switching capabilities ... needs SVI to be enabled.
I do this on my routers in this manner ... maybe this will guide you in the right direction ... although this post is quite old I am sure it was already figured out 😛
ethernet-internal subslot 1/0
platform switchport svi
