Cisco Issue - Hardware or Software?
JCubio
Community Member
Hi Experts,
I have this weird issue on one of our switches Few ports are not working properly. When I plugged a computer on the port I always get "Unidentified Network"
These ports are 1,2.46 and 25 as far I've tested.
I already tried plugging in a laptop directly to the switch to make sure that it's not a faulty cable issue. And I get the same result, but when I tried plugging it in a different port in the same switch. I'm able to connect to the network/internet.
Also all ports have same config. Only port 50 is in trunk mode which is connected to the other switch.
Device Details:
1. Model - SG500-52
2. Firmware -  1.4.11.4
Please advise
Thank you.
Mark Elsen
 - This might well be a 'local problem' on your PC. Check network settings/assigned IP/etc <-> compliance with your Intranet networking setup and addressing (e.g.).
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
The original post asks whether this is likely a hardware issue or a software issue. We do not have enough information to know that. But my guess based on the little that we know is that it is more likely software than hardware. If this were a regular Catalyst switch I would look into the output of show interface status and of show vlan to investigate. I am not sure what the equivalent is on this platform.
Rick
hassanshibu
Frequent Visitor
Frequent Visitor
You can try making the port to default configuration and disabling/enabling the POE.Also check the logg and show interface output to get more details.
Hi Sir,
It's not POE switch.
Also I tried copying the config of working ports but it doesn't help
