Cisco Nexus 5596UP Switch
Szabo Tomi
Hi All,
We have a Nexus Switch. If we would like to save the configuration, we don't success.
The Problem is:
"Nexus1# copy running-config startup-config
####################################### 100%
Configuration update aborted: request was aborted"
Our information:
"Usage for bootflash://sup-local
1173573632 bytes used
  477331456 bytes free
1650905088 bytes total
Nexus1# dir debug:
Usage for debug://sup-local
          0 bytes used
   20971520 bytes free
   20971520 bytes total
Nexus1# dir log:
         31    Aug 10 03:26:05 2017  dmesg
          0    Aug 10 03:26:27 2017  libfipf.3369
          0    Aug 10 03:26:34 2017  libfipf.3498
    4194304    Jan 14 14:03:32 2019  messages
          0    Aug 10 03:26:34 2017  snmp_log
        920    Aug 10 03:28:15 2017  startupdebug
       2540    Aug 10 03:28:19 2017  syslogd_ha_debug
Usage for log://sup-local
  112836608 bytes used
  306593792 bytes free
  419430400 bytes total
Nexus1# dir modeflash:
No such file or directory
Nexus1# dir modflash:
no such file or directory (invalid server)"
What I should do?
Try the software upgrade to newer? (Now is running the 7.1(3)N1(1))
Thanks for your help,
Tamas
balaji.bandi
i see one of the same in reltaed you see the error. but other platform in related to nexus OS.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc77151/?rfs=iqvred
BB
balaji.bandi
BB
I seen this on my 5ks couple years back known bug , its done the rounds on the NX-OS software , a reboot should resolve it but we ended up upgrading at the same time too, to be sure
Im using this currently on my 5596s no issues with it running long time now
# sh ver | i 5596
cisco Nexus 5596 Chassis ("O2 48X10GE/Modular Supervisor")
# sh ver | i 7
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Module 1: v7.0
kickstart: version 7.3(3)N1(1)
system: version 7.3(3)N1(1)
kickstart image file is: bootflash:///n5000-uk9-kickstart.7.3.3.N1.1.bin
kickstart compile time: 4/27/2018 9:00:00 [04/27/2018 17:18:59]
system image file is: bootflash:///n5000-uk9.7.3.3.N1.1.bin
system compile time: 4/27/2018 9:00:00 [04/27/2018 21:24:41]
Intel(R) Xeon(R) CPU with 8253792 kB of memory.
bootflash: 2007040 kB
Kernel uptime is 170 day(s), 22 hour(s), 58 minute(s), 16 second(s)
Last reset at 279537 usecs after Sat Jul 28 11:26:47 2018
System version: 7.1(4)N1(1)
we have the same problem and the Workaround does not apply for the
Nexus 5596 Chassis with actual SW: system: version 7.3(3)N1(1).
There is no Featur Name ( bash ) available to apply the workaround.
Please advise on a plausable workaround / solution.
Kind Regards,
Scottie
take a copy of the config, upgrade switch and reapply it then save it will work if no bash or else TAC it with Cisco
