Cisco Nexus 9000 "feature privilege"
johnlloyd_13
Level 9
Level 9
hi,
i'm trying to configure a new N9K and issued the "feature privilege" command but didn't accept it.
how can i enable this feature?
the NX-OS is 10.1
N9K(config)# feature privilege
% Invalid command at '^' marker.
N9K(config)# feature ?
analytics Enable/Disable Analytics!!!
bash-shell Enable/Disable bash-shell
bfd Bfd
bgp Enable/Disable Border Gateway Protocol (BGP)
container-tracker Enable/Disable NXOS Container Tracker
dhcp Enable/Disable DHCP Manager
dot1x Enable/Disable dot1x
eigrp Enable/Disable Enhanced Interior Gateway Routing
Protocol (EIGRP)
epbr Enable/Disable Enhanced Policy Based Routing
(EPBR)
evb Enable/Disable Edge Virtual Bridge (EVB)
evmed Enable/Disable Generic event detectors
fabric Enable/Disable Fabric Services
flexlink Enable/Disable Flexlink
frequency-synchronization Enable/Disable fsync
grpc Enable/Disable grpc Services
hardware-telemetry Enable/Disable Hardware Telemetry
hsrp Enable/Disable Hot Standby Router Protocol (HSRP)
imp Enable/Disable IMP
interface-vlan Enable/Disable interface vlan
isis Enable/Disable IS-IS Unicast Routing Protocol
(IS-IS)
itd Enable/Disable ITD
lacp Enable/Disable LACP
ldap Enable/Disable ldap
license License related commands
lldp Enable/Disable LLDP
macsec Enable/Disable CTS
mpls Enable/Disable MPLS Services
msdp Enable/Disable Multicast Source Discovery Protocol
(MSDP)
nat Enable/Disable NAT
nbm Enable/Disable Non Blocking Multicast (NBM)
feature
netconf Enable/Disable netconf Services
netflow Enable/Disable NetFlow
ngmvpn Enable/Disable EVPN/MVPN features
ngoam Enable/Disable ngoam
ntp Enable/Disable NTP
nv Enable/Disable VxLAN
nxapi Enable/Disable nxapi
nxsdk Enable/Disable nxsdk Services
ofm Enable/Disable OFM
openflow Enable/Disable OpenFlow agent
ospf Enable/Disable Open Shortest Path First Protocol
(OSPF)
ospfv3 Enable/Disable Open Shortest Path First Version 3
Protocol (OSPFv3)
password Credential(s) for the user(s)/device(s)
pbr Enable/Disable Policy Based Routing(PBR)
pim Enable/Disable Protocol Independent Multicast
(PIM)
pim6 Enable/Disable Protocol Independent Multicast
(PIM) for IPv6
pnp Enable/Disable PNP
port-security Enable/Disable port-security
private-vlan Enable/Disable private-vlan
ptp Enable/Disable PTP
restconf Enable/Disable restconf Services
rip Enable/Disable Routing Information Protocol (RIP)
scheduler Enable/Disable scheduler
scp-server Enable/Disable SCP server
sflow Enable/Disable sFlow agent
sftp-server Enable/Disable SFTP server
signature-verification Enable image signature verification
sla Enable/Disable SLA
ssh Enable/Disable ssh
tacacs+ Enable/Disable tacacs+
telemetry Enable/Disable Telemetry
telnet Enable/Disable telnet
tunnel Enable/Disable Tunnel Manager
tunnel-encryption Enable/Disable Tunnel Encryptiontunnel-encryption
udld Enable/Disable UDLD
vmtracker Enable/Disable VM Tracker feature
vn-segment-vlan-based Enable/Disable VLAN based VN segment
vpc Enable/Disable VPC (Virtual Port Channel)
vrrp Enable/Disable Virtual Router Redundancy Protocol
(VRRP)
vrrpv3 Enable/Disable Virtual Router Redundancy Protocol
(VRRP) version 3
vtp Enable/Disable VTP
Software
BIOS: version 01.09
NXOS: version 10.1(1)
BIOS compile time: 10/08/2023
NXOS image file is: bootflash:///nxos.10.1.1.bin
NXOS compile time: 2/14/2021 15:00:00 [02/15/2021 01:41:40]
(config)# show feature
Feature Name Instance State
Flexlink 1 disabled
analytics 1 disabled
bash-shell 1 disabled
bfd 1 disabled
bgp 1 disabled
bluez 1 disabled
bulkstat 1 disabled
cable-management 1 disabled
catena 1 disabled
container-tracker 1 disabled
macsec 1 disabled
dhcp 1 disabled
dot1x 1 disabled
eigrp 1 disabled
eigrp 2 disabled
eigrp 3 disabled
eigrp 4 disabled
eigrp 5 disabled
eigrp 6 disabled
eigrp 7 disabled
eigrp 8 disabled
eigrp 9 disabled
eigrp 10 disabled
eigrp 11 disabled
eigrp 12 disabled
eigrp 13 disabled
eigrp 14 disabled
eigrp 15 disabled
eigrp 16 disabled
enm 1 disabled
epbr 1 disabled
eth-port-sec 1 disabled
evb 1 disabled
evc 1 disabled
evmed 1 disabled
fabric-access 1 disabled
fport-channel-trunk 1 disabled
fsync_mgr 1 disabled
grpc 1 disabled
hardware-telemetry 1 disabled
hmm 1 disabled
hsrp_engine 1 disabled
icam 1 enabled
imp 1 disabled
interface-vlan 1 disabled
intersight 1 disabled
isis 1 disabled
isis 2 disabled
isis 3 disabled
isis 4 disabled
isis 5 disabled
isis 6 disabled
isis 7 disabled
isis 8 disabled
isis 9 disabled
isis 10 disabled
isis 11 disabled
isis 12 disabled
isis 13 disabled
isis 14 disabled
isis 15 disabled
isis 16 disabled
itd 1 disabled
l2vpn 1 disabled
l3vpn 1 disabled
lacp 1 disabled
ldap 1 disabled
ldp 1 disabled
license-smart 1 disabled
license-smart-res 1 disabled
lldp 1 disabled
mpls-evpn 1 disabled
mpls_oam 1 disabled
mpls_static 1 disabled
msdp 1 disabled
mvpn 1 disabled
mvrp 1 disabled
nat 1 disabled
nbm 1 disabled
netconf 1 disabled
netflow 1 disabled
ngmvpn 1 disabled
ngoam 1 disabled
npiv 1 disabled
nve 1 disabled
nxapi 1 disabled
nxsdk_app1 1 disabled
nxsdk_app10 1 disabled
nxsdk_app11 1 disabled
nxsdk_app12 1 disabled
nxsdk_app13 1 disabled
nxsdk_app14 1 disabled
nxsdk_app15 1 disabled
nxsdk_app16 1 disabled
nxsdk_app17 1 disabled
nxsdk_app18 1 disabled
nxsdk_app19 1 disabled
nxsdk_app2 1 disabled
nxsdk_app20 1 disabled
nxsdk_app21 1 disabled
nxsdk_app22 1 disabled
nxsdk_app23 1 disabled
nxsdk_app24 1 disabled
nxsdk_app25 1 disabled
nxsdk_app26 1 disabled
nxsdk_app27 1 disabled
nxsdk_app28 1 disabled
nxsdk_app29 1 disabled
nxsdk_app3 1 disabled
nxsdk_app30 1 disabled
nxsdk_app31 1 disabled
nxsdk_app32 1 disabled
nxsdk_app4 1 disabled
nxsdk_app5 1 disabled
nxsdk_app6 1 disabled
nxsdk_app7 1 disabled
nxsdk_app8 1 disabled
nxsdk_app9 1 disabled
nxsdk_mgr 1 disabled
ofm 1 disabled
onep 1 disabled
openflow 1 disabled
ospf 1 disabled
ospf 2 disabled
ospf 3 disabled
ospf 4 disabled
ospf 5 disabled
ospf 6 disabled
ospf 7 disabled
ospf 8 disabled
ospf 9 disabled
ospf 10 disabled
ospf 11 disabled
ospf 12 disabled
ospf 13 disabled
ospf 14 disabled
ospf 15 disabled
ospf 16 disabled
ospfv3 1 disabled
ospfv3 2 disabled
ospfv3 3 disabled
ospfv3 4 disabled
ospfv3 5 disabled
ospfv3 6 disabled
ospfv3 7 disabled
ospfv3 8 disabled
ospfv3 9 disabled
ospfv3 10 disabled
ospfv3 11 disabled
ospfv3 12 disabled
ospfv3 13 disabled
ospfv3 14 disabled
ospfv3 15 disabled
ospfv3 16 disabled
pbr 1 disabled
pim 1 disabled
pim6 1 disabled
plb 1 disabled
poe 1 disabled
private-vlan 1 disabled
privilege 1 disabled    <<<<
ptp 1 disabled
restconf 1 disabled
rip 1 disabled
rip 2 disabled
rip 3 disabled
rip 4 disabled
rise 1 disabled
scheduler 1 disabled
scpServer 1 disabled
segment-routing 1 disabled
sflow 1 disabled
sftpServer 1 disabled
sla_responder 1 disabled
sla_sender 1 disabled
sla_twamp 1 disabled
smart-channel 1 disabled
srte 1 disabled
srv6 1 disabled
sshServer 1 enabled
tacacs 1 disabled
telnetServer 1 enabled
tun_enc_mgr 1 disabled
tunnel 1 disabled
udld 1 disabled
vmfex 1 disabled
vmtracker 1 disabled
vni 1 disabled
vnseg_vlan 1 disabled
vpc 1 disabled
vrrp 1 disabled
vrrpv3 1 disabled
vtp 1 disabled
5 Replies 5
marce1000
 - Review the output from                     N9K# show privilege
   and or have another  try after N9K(config)# username admin role priv-15
  M.
balaji.bandi
user show have network-admin privlage example :
username myadmin password  xxxxxxxxxxxxx role network-admin
BB
johnlloyd_13
Level 9
Level 9
it seems 'feature privilege' and 'enable secret' was discontinued in NX-OS 10.x
it's hard to find a cisco nexus doc related to this but found a thread in github instead.
https://github.com/ansible-collections/cisco.nxos/issues/304
the NX-OS is 10.1  - have noticed this, make sense.
BB
