cisco nexus 9000 VRRP Problem
Wesley She
I have two Cisco C93180YC-FX3 switches, I tried to set vrrp, but I found that if the server uses the same vlan as the upstream, its network speed will become very slow.
I have tried using only a single switch and found the result is the same.
My switch config and network structure are as below:
feature vrrp
feature interface-vlan
feature ssh
int vlan 1
ip address 172.20.1.247 255.255.254.0
no shutdown
vrrp 1
address 172.20.1.254
no shutdown
ip route 0.0.0.0 0.0.0.0 172.20.0.21
int e1/1-2
switchport
switchport mode access
switchport access vlan 1
no shutdown
Network structureNetwork structure
speed test result
balaji.bandi
is this vPC?  ( as per the diagram looks like back to back ?)  what speed does each switch connect interface? can you post the config of each witch and show interface x/x output?
BB
No, it is back to back.
To determine if VRRP is the problem, I only use one Cisco Nexus C93180YC-FX3 and have no vpc set up.
sw1 is C93180YC-FX3 and sw2 is cisco 2960x, the relevant config and interface information are as below.
SW1
hostname SW1
feature vrrp
feature ssh
int vlan 1
no shutdown
vrrp 1
no shutdown
int e1/1-2
switchport
no shutdown
SW1# show interface e1/1
Ethernet1/1 is up
admin state is up, Dedicated Interface
  Hardware: 100/1000/10000/25000 Ethernet, address: 1859.f5ef.a998 (bia 1859.f5ef.a998)
  MTU 1500 bytes, BW 1000000 Kbit , DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  full-duplex, 1000 Mb/s, media type is 1G
  Beacon is turned off
  Auto-Negotiation is turned on  FEC mode is Auto
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
    admin fec state is auto, oper fec state is off
  Last link flapped 00:08:12
  1 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 56 bits/sec, 0 packets/sec
    30 seconds output rate 816 bits/sec, 1 packets/sec
    input rate 56 bps, 0 pps; output rate 816 bps, 1 pps
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 104 bits/sec, 0 packets/sec
    300 seconds output rate 760 bits/sec, 1 packets/sec
    input rate 104 bps, 0 pps; output rate 760 bps, 1 pps
  RX
    17 unicast packets  13 multicast packets  8 broadcast packets
    38 input packets  5688 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    28 unicast packets  717 multicast packets  10 broadcast packets
    755 output packets  57114 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
SW1# show interface e1/2
Ethernet1/2 is up
  Hardware: 100/1000/10000/25000 Ethernet, address: 1859.f5ef.a999 (bia 1859.f5ef.a999)
  Port mode is access
  EtherType is 0x8100
  Last link flapped 00:08:37
  1 interface resets
    30 seconds input rate 440 bits/sec, 0 packets/sec
    30 seconds output rate 1024 bits/sec, 1 packets/sec
    input rate 440 bps, 0 pps; output rate 1.02 Kbps, 1 pps
    300 seconds input rate 216 bits/sec, 0 packets/sec
    300 seconds output rate 896 bits/sec, 1 packets/sec
    input rate 216 bps, 0 pps; output rate 896 bps, 1 pps
  RX
    228 unicast packets  10 multicast packets  3 broadcast packets
    241 input packets  32763 bytes
    0 Rx pause
  TX
    121 unicast packets  769 multicast packets  7 broadcast packets
    897 output packets  73515 bytes
    0 jumbo packets
    0 Tx pause
SW2
hostname SW2
vlan 30
int vlan 1
ip address 172.20.0.21 255.255.254.0
int vlan 30
ip address 192.168.30.31 255.255.255.0
ip routing
ip route 172.20.0.0 255.255.254.0 172.20.1.254
int g1/0/1
no shutdown
int g1/0/24
switchport access vlan 30
no shutdown
SW2#show interfaces gigabitEthernet 1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 701f.53c7.ff81 (bia 701f.53c7.ff81)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:04, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1034 packets input, 84323 bytes, 0 no buffer
     Received 905 broadcasts (898 multicasts)
     0 watchdog, 898 multicast, 0 pause input
     282 packets output, 40156 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
SW2#show interfaces gigabitEthernet 1/0/24
GigabitEthernet1/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 701f.53c7.ff98 (bia 701f.53c7.ff98)
  5 minute input rate 2000 bits/sec, 3 packets/sec
     2066 packets input, 204444 bytes, 0 no buffer
     Received 1710 broadcasts (880 multicasts)
     0 watchdog, 880 multicast, 0 pause input
     296 packets output, 49908 bytes, 0 underruns
If you are planning on keeping both switch-1 and 2 as layer-3, then you simply need to terminate vlan1 on switch-1 and vlan 30 on switch-2 and use a routed link or a vlan in access mode between the 2 switches.
server-vlan-1----switch-1------routed link------switch-2----vlan-30----client
If you are planning on keeping switch-1 as layer-2 only then you can extend vlan one all the way to switch-2 and use that switch to route between vlan-1 and vlan-30 and there is no need for a layer-3 link between the switches.
server-vlan-1----switch-1------vlan-1------switch-2----vlan-30----client
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/11072-inter-vlan-11072.html
please check this doc.
there is some limitation in using InterVLAN bridge,check cisco recommend.
note:- example in doc. is for 6500 but still can apply to NSK.
