[cisco packet tracer]'s weird ip default-gateway, why?
Translator
Community Manager
Community Manager
Configure the management IP for the three-layer switch (ip routing is not enabled), use ip default-gateway to set the default gateway, the result is that the computer ping in the vlan does not communicate with the svi of the network.
Set in the switch: ip default-gateway 192.168.1.1; Then on pc0, execute: ping 192.168.2.1, cannot ping!
pc0 and vlan2 in the same network segment, theoretically can be ping, the packet does not leave the network, gateway nothing. It just didn't work out. Why?
eafrempong
Did you find a solution ?
for that to work, you need inter-vlan routing enabled on the switch ip routing.
BB
Joseph W. Doherty
That makes no sense.  Also, shouldn't have anything to do with the PC using 192.168.2.2/24 pinging the switch's 192.168.2.1/24.
I created a similar setup, in PT (attached), and works fine for me.
Perhaps you can post your PT file?
