Cisco PoE switch and Power injector
amarula115
Can I use power injector with Cisco PoE enabled switch? Do I need to disable power on the switch port before connecting PoE injector to it?
Tim Y
Yes, you can use a power injector with a PoE enabled switch. You do not need to disable PoE on the port.
I hope this helps.
Tim
Thank you for a prompt answer
You're welcome, good luck!
Please don't forget to mark posts as correct and to rate useful posts.
Tim
