Cisco router 831 NAT issue
chicagotech
I try to configure a Cisco router 831 to open port 3389 for TS. The TS in the LAN is 172.6.5.2 and the AN port IP is 192.168.10.70. I add ?ip nat inside source static tcp 172.16.5.2 3389 192.168.10.70 3389 extendable?, but can?t access the TS from 192.168.10.100. This is the result of ?show ip nat translation?:
Pro Inside global Inside local Outside local Outside global
tcp 192.168.10.70:3389 172.16.5.2:3389 --- ---
tcp 192.168.10.70:3389 172.16.5.2:3389 192.168.10.100:2175 192.168.10.100:2175
This is configuration
version 12.3
no service pad
service password-encryption
hostname 831
logging buffered 52000 debugging
clock timezone America/Chicago -6
clock summer-time America/Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip domain name cisco.com
ip name-server 4.2.2.1
ip dhcp excluded-address 172.16.5.1 172.16.5.9
ip dhcp excluded-address 172.16.5.51 172.16.5.254
ip dhcp pool sdm-pool1
network 172.16.5.0 255.255.255.0
default-router 172.16.5.1
dns-server 4.2.2.1
no ip bootp server
ip inspect name sdm_ins_in_100 cuseeme
ip inspect name sdm_ins_in_100 ftp
ip inspect name sdm_ins_in_100 h323
ip inspect name sdm_ins_in_100 netshow
ip inspect name sdm_ins_in_100 rcmd
ip inspect name sdm_ins_in_100 realaudio
ip inspect name sdm_ins_in_100 rtsp
ip inspect name sdm_ins_in_100 smtp
ip inspect name sdm_ins_in_100 sqlnet
ip inspect name sdm_ins_in_100 streamworks
ip inspect name sdm_ins_in_100 tftp
ip inspect name sdm_ins_in_100 tcp
ip inspect name sdm_ins_in_100 udp
ip inspect name sdm_ins_in_100 vdolive
ip inspect name sdm_ins_in_100 icmp
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description $FW_INSIDE$$ETH-LAN$
ip address 172.16.5.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface Ethernet1
description $FW_OUTSIDE$$ETH-WAN$
ip address 192.168.10.70 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect sdm_ins_in_100 in
duplex auto
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip nat inside source list 1 interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1 permanent
ip http server
ip http authentication local
ip http secure-server
access-list 1 permit 172.0.0.0 0.255.255.255
no cdp run
banner login ^CCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
2 Accepted Solutions
Can you modify the static NAT as follows to point to the interface (e1) instead of the IP address. I have seen issues when the NAT is configured to use the IP address that's already configured on an interface.
no ip nat inside source static tcp 172.16.5.2 3389 192.168.10.70 3389 extendable
ip nat inside source static tcp 172.16.5.2 3389 ethernet1 3389 extendable
Sundar
couple of simple things to test,
Can you ping 172.16.5.2 from router?
Is 172.16.5.2 is windows XP SP2 machine? if yes make sure its firewall is allowing inbound 3389, or you can turn it off and try to see if it resolve the issue.
Muhammad
6 Replies 6
Sundar
Thank you for the reply. We have some issues here.
1. When trying to do ?no ip nat inside source static tcp 172.16.5.2 3389 192.168.10.70 3389 extendable?, I receive ?Entry in use, cannot delete? message?. I tried to use this command ?clear ip nat translation *? to clear the translation, but still cannot delete it. What I deleted it is using SDM.
2. When trying ?ip nat inside source static tcp 172.16.5.2 3389 ethernet1 3389 extendable?, I receive this message
^ (pointing to Ethernet)
% Invalid input detected at '^' marker.
3. If I try ?ip nat inside source static tcp 172.16.5.2 3389 interface ethernet1 extendable?, I receive this message
ip nat inside source static tcp 172.16.5.2 3389 interface ethernet1 3389 extendable
^ (pointing to extendable)
4. Finally, it takes ?ip nat inside source static tcp 172.16.5.2 3389 interface ethernet1 3389?. However, I still can?t access the 172.16.5.2 using port 3389. here is the ip nat translation:
831#sh ip nat trans
tcp 192.168.10.70:3389 172.16.5.2:3389 192.168.10.100:3482 192.168.10.100:348
Any suggestions for above issues?
Muhammad
1. Yes, I can ping 172.16.5.2 from the router. This is the result.
831#ping 172.16.5.2
Sending 5, 100-byte ICMP Echos to 172.16.5.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
2. I have two Windows 2003 servers (172.16.5.2 and 172.16.5.10) without any firewall/RRAS/NAT enabled. They can access each other using TS without any issues.
3. I also tried to configure NAT using the IP 172.16.5.10 (ip nat inside source static tcp 172.16.5.10 3389 interface ethernet1 3389). Same result.
ny other sugegstions?
Your problem is dynamic natting is taking over static nat translation
try to define your pool to exclude those two servers from dynamic natting
then it should work.
check this link
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml#qa17
Hope this helps
Raj
OK, finally fixed it. It is no thing wrong with the Cisco configuration. It is because the TS is multihomed computer. Disable one NIC and keeps 172 subnet only. It works. Thank you very much.
