Cisco 4506 Problem
suresharja
Level 3
Level 3
Hi All,
How to find out my Switch is having CATOS or IOS ? 5 Ethernet Ports in one module are not working.Rest of the ports are working fine. Any workaround ?
6 Replies 6
amit-singh
Level 11
Level 11
Run " show version " on the switch.Check for the supervisor engine you are running on the switch.
Sup engine 2 i.e WS-X4013 supports CatOS.
Rest all the sup engines i.e Sup2+10GE/4/5/5-10GE supports IOS.
Please paste the show version here and we will be able to let you know about it more.
If your 5 ports on the module are not working, I would suggest to run the diagnostic tests on the switch to find out any hardware issues.
" Show diagnostic result module "
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_25a/cmdref/show1.htm#wp2031546
HTH,Please rate if it does.
-amit singh
Hi amith,
Can I do it while other servers are online on the same module ?
I have Supervisor Engine IV (WS-X4515).I have IOS only.
Suresh
Yes, it should not be an issue. You can still run the test on the switch.
HTH,
-amit singh
Hi Amith,
I have attached the output of the two commands.
Switch # sh diagnostic result module 3
module 3:
Overall diagnostic result: PASS
Test results: (. = Pass, F = Fail, U = Untested)
1) linecard-online-diag --------------------> .
Switch # sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Versi
on 12.2(31)SG, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 14-Mar-06 15:38 by ssearch
Image text-base: 0x10000000, data-base: 0x114C8524
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 31
CTSINHYD_PNR_1F_B uptime is 19 weeks, 3 days, 21 hours, 2 minutes
System image file is "bootflash:"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4506 (MPC8245) processor (revision 14) with 524288K bytes of memory.
Processor board ID FOX1010121E
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
3 Virtual Ethernet interfaces
192 FastEthernet interfaces
2 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Kindly sugest me how to go about the not working switch Ports.
Suresh
Test is passed that means there is not hardware issue with the ports on the module.
What do you mean by that ports are not working. is it that you are connect ing the PC to it and the port is not coming up?
-amit singh
And one more thing to point out is that u r configuration-register isnt it should be 0x2102.
Mahmood
