cisco routers between utm firewall sending hello...Adjacency??
CSCO12550173
Hello this is my first post
because i want to know something about redirect hello packets
well this is the case, i have a cisco 800 series with eigrp, connected with a dedicated link to a UTM firewall
and then this firewall has in a LAN segment a cisco 2900 sending eigrp packets
wich is the best aproach, redirect the eigrp hello between them ?
Thanks for your time
Best Regards
John Blakley
I would say allow protocol 88 (eigrp) through the firewall between the two addresses. You may also try to set up unicast peering (with neighbor command) between the two routers so multicast packet doesn't get blocked...
HTH,
John
HTH, John *** Please rate all useful posts ***
