I own a CISCO RV340 Router. This Router was purchased via Amazon India.
I am facing a problem in the LINK/ACT LED display on the port of LAN-1 in the router.
The LAN-1 port of the RV340 is connected to an unmanaged Switch and in turn the Switch renders connection to 2 laptops and 1 raspberry pi. When the Router RV340 is switched ON, the Unmanaged switch is switched ON at the same time along with the raspberry pi.
Now, the problem. The LINK/ACT LED light on LAN port 1 will switch off after 1 or 2 hours of router remaining ON even if it is connected to an Ethernet Unmanaged Switch. At this point, the Gigabit LED light below the LINK/ACT LED will remain ON but the Link/Act will stay switched off.
The LED lights do not switch back on even after all the devices connected to the Unmanaged switch (that is connected to LAN-1) are switched ON and internet browsing is done on the laptops. The internet browsing is at good speed and hence the connectivity from LAN1 pf Router RV340 to Ethernet Switch to Laptop is very much present and working well. But the Link/Act LED will not come back as ON instantly when the browsing the net in the laptop as started.
Please help to understand why does the LINK/ACT LED light turn off automatically after 1 or 2 hours. Is this router having a faulty LED light and this router needs to be replaced ?
