Cisco SG350 Port channel interface doesn't hold allowed vlan conf
Joe Hunter
I have a cisco SG350 configured to connect with a cisco WS-C2960X over etherchannel, both switch are on LACP.
I want to add a Vlan as allowed one on port channel interface of SG350, but this one doesn't take the config.
By the way, I was able to add the vlan on WS-C2960X.
You find below my config:
WS-C2960X:
Building configuration...
Current configuration : 241 bytes
interface Port-channel2
description "Vers Switch-SA-FABLAB-46"
switchport trunk native vlan 2
switchport trunk allowed vlan 2,12,60
switchport mode trunk
spanning-tree link-type point-to-point
spanning-tree guard root
end
SG350:
interface Port-Channel1
description "Vers Switch"
ip dhcp snooping trust
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) LACP Te1/0/1(P) Te2/0/1(P)
2 Po2(SU) LACP Gi4/0/45(P) Gi4/0/46(P)
Can you please help ?
Best regards,
7 Replies 7
DanielP211
Are you trying over GUI or CLI? You should add the tagged vlans and it should work. Could you paste the config from the 350?
BR
****Kindly rate all useful posts*****
Thank you DanielP211 for your answer.
I'm trying to configure this over CLI.
Please find below the SG350 conf:
config-file-header
EIFFEL-E1-SA-FABLAB-46
v2.4.0.94 / RTESLA2.4_930_181_045
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
cdp device-id format hostname
vlan database
vlan 2,12,60
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname E1-SA-FABLAB-46
line console
exec-timeout 45
exit
line ssh
exec-timeout 45
exit
line telnet
exec-timeout 45
exit
line console
no autobaud
exit
encrypted radius-server host
management access-list MGMT-SSH
permit ip-source 10.4.252.100 service snmp
permit ip-source 10.22.1.92 service snmp
permit ip-source 10.22.1.249 service snmp
permit ip-source 10.22.1.250 service snmp
permit ip-source 10.3.1.77 service snmp
permit ip-source 10.3.1.202 service ssh
permit ip-source 10.3.1.202 service telnet
permit ip-source 10.3.5.62 service https
permit ip-source 10.3.5.62 service ssh
permit ip-source 10.3.5.62 service telnet
permit ip-source 10.7.3.0 mask 255.255.255.0 service https
permit ip-source 10.7.3.0 mask 255.255.255.0 service ssh
permit ip-source 10.7.3.0 mask 255.255.255.0 service telnet
permit ip-source 10.34.100.0 mask 255.255.255.0 service https
permit ip-source 10.34.100.0 mask 255.255.255.0 service ssh
permit ip-source 10.34.100.0 mask 255.255.255.0 service telnet
permit ip-source 10.22.1.99 service snmp
exit
management access-class MGMT-SSH
aaa authentication login SSH radius local
aaa authentication enable SSH radius enable
aaa authentication login Telnet radius local
aaa authentication enable Telnet radius enable
aaa authentication login Console local
aaa authentication enable Console enable
aaa authentication login default radius local
line telnet
login authentication Telnet
enable authentication Telnet
exit
line ssh
login authentication SSH
enable authentication SSH
exit
line console
login authentication Console
enable authentication Console
exit
enable
passwords complexity min-length 12
passwords complexity no-repeat 5
passwords aging 0
username admin
ip ssh server
snmp-server server
snmp-server engineID local
snmp-server group snmpv3 v3 priv
encrypted snmp-server user adm-snmp snmpv3 v3 auth sha
no ip http server
no ip http secure-server
clock timezone EU +1
clock summer-time eu recurring last sun mar 02:00 last sun oct 03:00
interface vlan 1
shutdown
interface vlan 2
name IID2_Management
ip address 10.5.2.46 255.255.255.0
interface vlan 12
name "PC-Peda VID12"
interface GigabitEthernet1
description "PC-Peda VID12"
spanning-tree portfast
spanning-tree bpduguard enable
switchport access vlan 12
no cdp enable
interface GigabitEthernet2
description "PC-Peda VID10"
switchport access vlan 10
no cdp enable
interface GigabitEthernet3
no cdp enable
interface GigabitEthernet4
no cdp enable
interface GigabitEthernet5
no cdp enable
interface GigabitEthernet6
no cdp enable
interface GigabitEthernet7
no cdp enable
interface GigabitEthernet8
no cdp enable
interface GigabitEthernet9
no cdp enable
interface GigabitEthernet10
no cdp enable
interface GigabitEthernet11
no cdp enable
interface GigabitEthernet12
no cdp enable
interface GigabitEthernet13
negotiation 100h
description "PC-Peda VID60"
switchport access vlan 60
no cdp enable
interface GigabitEthernet14
no cdp enable
interface GigabitEthernet15
no cdp enable
interface GigabitEthernet16
no cdp enable
interface GigabitEthernet17
no cdp enable
interface GigabitEthernet18
no cdp enable
interface GigabitEthernet19
no cdp enable
interface GigabitEthernet20
no cdp enable
interface GigabitEthernet21
no cdp enable
interface GigabitEthernet22
no cdp enable
interface GigabitEthernet23
no cdp enable
interface GigabitEthernet24
no cdp enable
interface GigabitEthernet25
channel-group 1 mode auto
interface GigabitEthernet26
exit
banner login
macro auto disabled
ip dhcp snooping
ip default-gateway 10.5.2.1
Joe Hunter
i'm trying to do this over CLI.
Below the SG350 config:
config-file-header
CLI v1.0
ssd-control-start
ssd config
ssd-control-end
vlan database
vlan 2,12,60
exit
line console
exec-timeout 45
exit
line ssh
exec-timeout 45
exit
line telnet
exec-timeout 45
exit
line console
no autobaud
exit
exit
line telnet
exit
line ssh
exit
line console
exit
enable
passwords aging 0
username admin
ip ssh server
snmp-server server
no ip http server
interface vlan 1
shutdown
interface vlan 2
interface vlan 12
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
negotiation 100h
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
exit
banner login
macro auto disabled
ip dhcp snooping
Torbjørn
I believe you need to add allowed vlans with the "add" keyword, not as a complete list like on regular IOS. E.g.
switchport trunk allowed vlan add 2
switchport trunk allowed vlan add 12
switchport trunk allowed vlan add 60
! You might be able to add them as a list, but the "add" is required.
switchport trunk allowed vlan add 2,12,60
See the relevant configuration guide: https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb4986-vlan-configuration-via-cli-on-300-500-series-managed-switche.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
I did this, but when i check the interface i dont see the allowed vlan line:
E1-SA-FABL...(config-if)#switchport trunk allowed vlan add 60
E1-SA-FABL...(config-if)#switchport trunk allowed vlan add 2
E1-SA-FABL...(config-if)#switchport trunk allowed vlan add 12
E1-SA-FABL...(config-if)#do show running-config interface po1
Hmm, this should work. I wonder if it truncates this line due to being equal to "all" vlans? Could you try to add just 2 of the VLANs to the allowed list on the trunk to see if it behaves differently?
Hello!
Use the command:
int po1
You can later check with the show vlan command which VID's are assigned.
BR
