PBR with ip next-hop
sebastien3
Level 4
Level 4
Is it possible on a 3750X switch to use PBR to force the use of a loopback as next-hop ?
I tried the following configuration but it doesn't work :
ping 10.10.10.100 source lo0 = PING OK
ping 10.10.10.100 source vlan10 = PING KO !
ip access-list extended ACL_PBR
 permit ip 10.0.0.0 0.0.0.3 any
route-map PBR permit 10
 match ip address ACL_PBR
 set ip next-hop 192.168.1.103
interface Loopback0
 ip address 192.168.1.103 255.255.255.255
interface Vlan10
 description *TEST PBR*
 ip address 10.0.0.1 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip policy route-map PBR
Thanks !
DanielP211
Hello!
You cannot have the next hop address as yourself? Why would you like to achieve that?
BR
****Kindly rate all useful posts*****
Torbjørn
I believe you are not hitting your PBR route-map at all currently as PBR is only evaluated for ingress traffic for the interface. You can verify this with debug ip policy.
I am also a bit confused as to what you are trying to achieve here.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
M02@rt37
Hello @sebastien3,
What do you want to do at final ? Test basicly PBR or a way to blackhole trafic ?
Best regards
