Cisco sg500x ACL on vlan interface
I am trying to configure acl in a cisco sg500x switch, and to apply tge acl binding on vlan interface. But to my surprise, the service-acl command is not working under vlan interfaces. But in the command reference guide on sg500, it is mentioned that the command is available for vlan also. Anybody has some solution for this? Unnikrishnan.
Reza Sharifi
Here is a guide on how to configure acl step-by-step.
https://sbkb.cisco.com/CiscoSB/ukp.aspx?login=1&pid=2&app=search&vw=1&articleid=3025&donelr=1
Found the issue.. adter upgrading firmware to 1.3.5 it started working..
Diana Karolina Rojas
Hello Unnikrishnan,
I was looking information about your problem, but you are right, in the Command Guide this model of switches have the option to configure interface vlan access-list, but maybe this is a IOS version problem, did you try to configure this via GUI? what is your IOS software?
