Cisco StackWise Virtual 9407r
Hi dear,
I try to configure Cisco StackWise Virtual in switch 9407r but StackWise command are not support.
Below you find show version command output :
Switch#sh version
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 05-Nov-18 19:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.6.2r[FC1], RELEASE SOFTWARE (P)
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
None Subscription Smart License None
20 Replies 20
Jaderson Pessoa
Dear, abdelmoulamarhabi
On IOS XE Fuji 16.9.2 Stackwise Virtual is supported, only in single supervisor module configuration. Does your router have just a single supervisor module?
More information about.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-9/release_notes/ol-16-9-9400.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hi, Thank you for your reply. I have two supervisor.
But the probleme is the command about  virtuel stack are not available.
balaji.bandi
Look at the model support for Stack wise virtual
You should able to as per the documentation :
Startingwith CiscoIOS XE Fuji 16.9.1,CiscoStackWise Virtualis supportedon CiscoCatalyst9400 SeriesSwitches.This sectiondescribesthe CiscoStackWise Virtualfeaturesspecificto CiscoCatalyst9400 SeriesSwitches.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-9/configuration_guide/ha/b_169_ha_9400_cg/configuring_cisco_stackwise_virtual.pdf
what is the error you getting ?
BB
The commands of virtuel stack are not available.
here my lab test one with Cat 9500
#conf t
Enter configuration commands, one per
line. End with CNTL/Z.
(config)#stackwise-virtual     <--- can you post  here with ?
Please reload the switch for StackWise
Virtual configuration to take effect
BB
hi,
This command is not available : (config)#stackwise-virtual  .
Dear, abdelmoulamarhabi1
Cisco StackWise Virtual is a network system virtualization technology that pairs two switches into one virtual switch to simplify operational efficiency with a single control and management plane.
Note
The feature is supported only on these chassis models and supervisor modules:
Chassis Models—Catalyst 9404R Switch and Catalyst 9407R Switch.
Supervisor Modules
Cisco Catalyst 9400 Series Supervisor 1 Module (C9400-SUP-1). The feature requires a special, additional, C9400-SUP-UPG-LIC= license with this supervisor module. << LICENSE REQUIRED.
Cisco Catalyst 9400 Series Supervisor 1XL Module(C9400-SUP-1XL).
Does your router has license to support it?
Information about your router below;
Jaderson Pessoa
Thank you to find below license information in my switch :
Switch#sh license usage
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 89 days, 19 hours, 57 minutes, 12 seconds
(essentialsk9-C9400):
Description:
Count: 2
Version: 1.0
Status: EVAL MODE
Export status: NOT RESTRICTED
Switch#sh lic
Switch#sh license sta
Switch#sh license status
Smart Licensing is ENABLED
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: Not Allowed
Status: EVAL MODE
Evaluation Period Remaining: 89 days, 19 hours, 57 minutes, 8 seconds
Export Authorization Key:
Features Authorized:
<none>
Dear abdelmoulamarhabi1
Your router doenst have license to support this.
Jaderson Pessoa
Can you please give me license squ that will be use to support that?
supervisor modules:
Note
• Chassis Models—Catalyst 9404R Switch and Catalyst
9407R Switch.
• Supervisor Modules
• Cisco Catalyst 9400 Series Supervisor 1 Module
additional, C9400-SUP-UPG-LIC= license with this << this license its necessary.
supervisor module.
• Cisco Catalyst 9400 Series Supervisor 1XL
Jaderson Pessoa
Can you post show modules
BB
Thank you to find below show module :
Switch#show module
Chassis Type: C9407R
Mod Ports Card Type Model Serial No.
1 48 48-Port 10/100/1000 (RJ-45) C9400-LC-48T JAE22420N0W
2 48 48-Port 1 Gigabit Ethernet (SFP) C9400-LC-48S JAE224003M9
3 10 Supervisor 1 XL Module C9400-SUP-1XL JAE224711BV
4 10 Supervisor 1 XL Module C9400-SUP-1XL JAE224810BG
Mod MAC addresses Hw Fw Sw Status
1 A8B4.5622.B4A4 to A8B4.5622.B4D3 1.1 16.6.2r[FC1] 16.09.02 ok
2 A8B4.5642.54F4 to A8B4.5642.5523 1.0 16.6.2r[FC1] 16.09.02 ok
3 D4C9.3C2A.A12C to D4C9.3C2A.A135 2.0 16.6.2r[FC1] 16.09.02 ok
4 D4C9.3C2A.A136 to D4C9.3C2A.A13F 2.0 16.6.2r[FC1] 16.09.02 ok
Mod Redundancy Role Operating Redundancy Mode Configured Redundancy Mode
3 Active sso sso
4 Standby sso sso
 9407R   - Need  NetworkAdvantage License  for Stack-wise Virtual. ( i believe) never had chance to work on that..soon i will, but we deployed 9500 advantage license.
BB
